Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 04-07-2002, 08:14 PM   #1
JrnymnJay
JrnymnJay's Avatar
Profile:
Images: 11
Removing Vulkem
Anyone out there have experience removing Vulkem and other types of sealant?
The best method I've heard of was to use sharpened popcicle sticks or paint stirrers. But I've got a lot of the stuff to remove on the outside of my trailer...terrible labor intensive, but I want it clean so it can be polished and looks better.
Anyone know of a solvent for the stuff?
Jay
JrnymnJay is offline   Reply With Quote
Old 04-07-2002, 09:56 PM   #2
JrnymnJay
JrnymnJay's Avatar
Profile:
Images: 11
to clarify, I'm not positive that the exterior material is Vulkem.
I'm assuming it is due to it's flexibility and grayish color.
Old 04-08-2002, 03:03 PM   #3
Jerry Sulkin
Profile:
Removing that stuff is very labor intensive. My 71 Safari has Vulcum all over the roof seams around the vents and every penetration about 1/4" thick and 2" to 3" wide. My method of removal is to use a very sharp 1/2" wide wood chisel and shave off as much as you can before you get to the aluminum. Then use BIX spray-on paint remover. Let it set for about 30 minutes. Again use the chisel to remove as much as possible and reapply the BIX and start the proceedure again. It takes sometimes five applications and lots of paper towels to get it all off. After you're done wash down with clean water to remove any leftover residue.
Good Luck.
Jerry
Jerry Sulkin is offline   Reply With Quote
Old 05-04-2002, 12:49 AM   #4
Sojourner
Sojourner's Avatar
Profile:
Goof-Off is 100% xylene and is available at Home Depot and other home improvement stores. It will cut ureathane caulk such as Vulkem very quickly using wiping rags, but is a very *hot* solvent and should only be used in a very well ventilated area (unless you're using an appropriate respirator) while using appropriate gloves (such as PVC gloves). Naptha will work as well, but slightly slower than xylene.
I haven't tried either on the plasti-coat to see if the plasti-coat will be affected, so you might want to try a small area first to check for any effect on the plasti-coat.
Sojourner is offline   Reply With Quote
Removing rear skin due to dents IPM Ribs, Skins & Rivets 11 09-02-2003 11:11 AM
Removing rear twin beds Bud Brown 2001 Safari 1 08-18-2003 07:05 PM
Removing wallpaper from 76 tradewind Rennegarbe1 Upholstery, Blinds, Walls & Interior Finishes 4 02-05-2003 05:52 AM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 08:15 AM
