Old 07-16-2007, 12:21 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Removing old Vulkem?
Any tips on how to remove old Vulkem from window edges and the like? I know that you shouldn't use a metal scraper, but that's about it.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 07-16-2007, 12:30 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 97
We used popsicle sticks. Sharpen the tip to a point and use it to scrape out the old stuff...the wood is soft enough that it won't scratch the aluminum, but firm enough to get the "goo" out.
You can buy a pack of them at your local hobby store or invite a bunch of kids over and treat them to Popsicles on a hot day...as long as they give you the sticks!
Shari
BIRDY - our 1956 Safari | 1964 Serro Scotty | 1946 Curtis Wright Model 2
Old 07-16-2007, 12:40 PM   #3
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Heat gun, but not too hot.
wacnstac is offline   Reply With Quote
Old 07-16-2007, 03:14 PM   #4
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Smile Hi Mike,
Someone said to use WD40. This will soften the goop. I know that WD40 works on removing clue from tape. I have not used it yet for that purpose but will in near future. Regards from Russell in hot Tucson Az.
RUSSELL is offline   Reply With Quote
Old 07-16-2007, 03:17 PM   #5
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
LOL, A heat gun, eh? Would 110 degree temperatures here in Phoenix be hot enough?
1958 Overlander
4CU 1st VP
Old 07-16-2007, 03:28 PM   #6
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I use a heat gun on medium setting...around 400-800 degrees, just don't leave it in one place too long
Then use Popsicle sticks or if your wife does manicures an orange stick works pretty good too.
Aaron
WBCCI #XXXX AIR #2495
Old 07-16-2007, 03:44 PM   #7
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
You could use a reflector and double or triple that Phoniex sunshine to get enough heat - but a heat gun is your best bet, I can attest to the sunburn one can/will get working on, beside or near an Airstream in full sun!
Old 07-16-2007, 04:43 PM   #8
1973 25' Tradewind
Parksville , British Columbia
Before running out to buy a heat gun try using a hair dryer to soften up the Vulkamen...I frequently used a hair dryer to thaw frozen water lines in my barn...have the popsicle sticks at the ready.
Cheer's
Callummor, (a "canny" Scot)
callummor is offline   Reply With Quote
Old 07-16-2007, 04:49 PM   #9
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Send a message via ICQ to 53flyingcloud Send a message via Yahoo to 53flyingcloud
Use an old orange stick with a sharpen angle point, or you could use a insulated tweaker with the metal tip removed(again, a shapen point). If you have steady hands, you could also use one of my favorite..A stainless steel tooth pick bought at Wally's World..The point get into the tighest gap, plus, when you're finis using it it has a handy case for storage.
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 07-16-2007, 05:15 PM   #10
bibbs's Avatar
Webster , New York
prep solvent [automotive paint supply] works on all goop, silicone and vulkum
realy cleans nice
Doug
bibbs is offline   Reply With Quote
removing Dometic Refrigerator smily Refrigerators 16 08-18-2010 03:36 AM
Removing wallpaper from 76 tradewind Rennegarbe1 Upholstery, Blinds, Walls & Interior Finishes 4 02-05-2003 04:52 AM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
Removing Vulkem JrnymnJay Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-03-2002 11:49 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
