Mineral spirits will help with the clean up. But my experience with Vulkem doesn't have the word easy in it !! A lot of elbow grease is necessary to remove aged Vulkem.
If you found anything that would dissolve vulkem, you would not want to touch it! It would be dangerous !
You might try a little lacquer thinner to help remove some residue, but even that stuff is dangerous.
1968 Overlander Land Yacht International
Ford E-350 W V-10 booom!
2018 Chevy Tahoe smooooooth
Find a way to enjoy life and have fun, every day !
A heat gun carefully used will soften it and you can use a plastic scraper to get most of it off.Be careful and don't get any area too hot.
Lacquer thinner will dissolve what you can't get off with the scraper and heating. I just removed the fridge vent to install some fans to help with fridge cooling and it worked great. If the surface isn't visible a scotchbrite pad soaked in lacquer thinner just rubs the old vulkem off the aluminum. Don't use too much pressure or you will scratch the surface. Wear thick glove for protection.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
