Old 11-04-2005, 10:26 AM   #1
1972 31' Sovereign
mountain view , California
Removing old "vulkem"?
I am looking at recaulking around all my windows because the old original stuff is bad. I have found many threads on polishing and gasket redos but havn't seen how to remove this stuff. I can't use anything metal because of digging into the sheetmetal. What do I use? This stuff if very hard and I don't think I can get back underneath it but if I can just get it off the surface then I can cover it with something new. I havn't decided on what to use for the sealant yet as everyone seems to like something different. Should I find a plastic putty knife? Or a wooden something?
reece1107 is offline   Reply With Quote
Old 11-04-2005, 10:34 AM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
hi Reece,
I have found that sharpened popsicle sticks and orange sticks work the best. I also try to soften the old vulkem using a heat gun. Once you get the old stuff out a good wipe/scrub down with mineral spirits and you will be ready to put new Vulkem in place.
Aaron
WBCCI #XXXX AIR #2495
Old 11-04-2005, 10:40 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
How about these, Acrylic Razor Blades. I have not used them myself, but I think they would work for what you want to do. Anyone have any experiance with these? I saw them at AirstreamDreams...opps...I mean VTS.
http://www.vintagetrailersupply.com/...Code=VTS%2D176
Richard
Old 11-04-2005, 08:19 PM   #4
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
do a search here there are many articles on that....
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 11-04-2005, 09:01 PM   #5
Wardinbb's Avatar
1964 24' Tradewind
Big Bear Lake , California
Above advice works good
Reece,
I'd like to add my 2cents here. I've used the sharpened popcicle sticks, plastic putty knifes, orange sticks, bamboo skewers and metal dental picks. All work fine. The best stuff is aerosol gun barrel scrubber. Used to use Hoppes #9 but its no longer available in the silly state of CA. WalMart and KMart have plenty of another brand. This stuff, if it doesn't liquidify the vulcum, at least will soften it. Once the old is removed by whichever tool works best for you, I tape off the seam on both sides and apply the vulcum using a syringe and force into place with a finger. The finger is in a latex glove mind you. The aerosol spray on a paper towel will remove any excess you don't want.
Cheers,
Ed
Wardinbb is offline   Reply With Quote
Removing the body shell and installing new floor completely - any one done this? williamhenshall Repairing/Replacing Floor &/or Frame 11 03-13-2006 11:21 AM
Removing wallpaper from 76 tradewind Rennegarbe1 Upholstery, Blinds, Walls & Interior Finishes 4 02-05-2003 04:52 AM
Vulken and Polish or Polish then Vulkem? rookie Cleaning, Stripping & Polishing 5 07-23-2002 07:15 AM
Removing Vulkem JrnymnJay Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 05-03-2002 11:49 PM
