Old 06-21-2013, 11:17 AM   #1
1999 25' Safari
Somewhere , Ohio
Removing old sealant from seams.
Would someone please share with me how to remove old sealant from the exterior seams? As soon as I have the polishing completed, I need to remove the remaining old sealant and reseal the seams.
I've been using the "Search" function as well as looking through various other threads hoping to come across this information, but have not come up with anything.
Thank you.
Deb
Air Cruiser is offline   Reply With Quote
Old 06-21-2013, 11:24 AM   #2
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
I'm sure everyone has their favorite way to do it.....but....here's one: Soften up the old sealant with de-natured alcohol or spray seams with WD-40. Let it sit over night. Then use a sharpened WOOD popsicle stick or the edge of a wooden shim...or a plastic putty knife and slowly and carefully dig the old stuff out. Do not use anything metal to dig out the seams, or it will leave marks.
arktos55343 is offline   Reply With Quote
Old 06-21-2013, 06:05 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I used no 'chemical'.. only a Dremel tool with wire brush attachment..
ONLY use this if you are very skilled with the Dremel, because it WILL leave marks even when you have an 'accident'... Plastic scrapers are more forgiving.
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-21-2013, 06:25 PM   #4
reinergirl's Avatar
Hollis , New Hampshire
I use my old standby, Citrastrip , painted on, and I let it sit for a couple hours. Then I use a wood craft stick (like Popsicle stick but wider) that I cut in the center on a 45 degree angle. That gives me 2 "tools" out of one stick. I also use an old toothbrush to scrub the seam and plastic scrapers as necessary. If I want to dig into the seam a little more a bamboo kitchen skewer works well.
A little bit of everything I guess Heck I even use my fingernails, which is why my manicure looks like heck!
So far citristrip has removed everything but I have the silicone remover from VTS on standby if necessary.
reinergirl is offline   Reply With Quote
Old 06-21-2013, 07:34 PM   #5
1999 25' Safari
Somewhere , Ohio
Thanks so much everyone. I had thought about the plastic scrapers, but quite a bit of the others, not. I was really stuck on how to loosen it up, and completely forgot about the CitriStrip! Wow, talk about a senior moment! I was so impressed with how it stripped the paint off of the interior skin I tried it on, then didn't even think of trying it on the old seam sealant.
Trying to get everything lined up so that when I get to the next stage, I have everything on-hand and don't have to run around getting "things". I want so badly to move on to the interior, I can taste it.
Deb
Old 06-22-2013, 08:24 AM   #6
mapleton , Utah
If you like the power tool route but the wire brush worries you try googling "3M bristle brush". recommended by Aerowood at the restoration rally a couple of years ago. Haven't tried it yet but it looks like a real time saver.
tim
rumrunner is offline   Reply With Quote
Old 06-22-2013, 12:32 PM   #7
1999 25' Safari
Somewhere , Ohio
Tim,
Thanks for sharing the info on the 3M bristle brush; I do like "power" whenever possible (makes it a little easier).
I went to the "shop3M.com" site, and read product descriptions, but didn't see anything to explain about the various grades and sizes. Do you happen to recall what Aerowood recommended as far as "grade" and "size" of the wheels? I just don't know what to order.
Thanks again.
Deb
Old 06-22-2013, 07:36 PM   #8
reinergirl's Avatar
Originally Posted by Air Cruiser View Post
Tim,
Thanks again.
Deb
Buy 3M 048011-18732 Scotch-Brite Roloc Bristle Abrasive Disc - Yellow - 2" x 5/8" - 80Grit at SkyGeek.com
I tried this, i thought maybe it would take off the black adhesive on my interior. I wasn't happy with the scratches. When I saw Aerowood using it he had used it on a window frame, that's different because it's solid aluminum and can be sanded pretty aggressively.
I'm sure he'll be along to comment.....and maybe I was doing something wrong, but I use them to take off gunk on solid aluminum only, not allclad.
Old 06-22-2013, 08:23 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I haven't polished my AS yet. Wonder how that will work?
Channing
WBCCI# 30676
Old 06-22-2013, 08:26 PM   #10
Mrs.Mod's Avatar
1977 31' Sovereign
Fresno , California
Hi there,
I used a plastic dish scrapper from my kitchen. It was the perfect tool for the job and did not scratch the aluminum. My old sealant was so degraded that I didn't need to used anything to loosen it up.
Good luck. It is not a fun job.
Cheers,
Cara, John & Johnny
Jet, Our silver stow-a-way
1977 31' Sovereign "The Mod Pod"
2006 Ford F-250 Super Duty
Mrs.Mod is offline   Reply With Quote
Old 06-22-2013, 08:39 PM   #11
reinergirl's Avatar
Oh, I forgot! I like these too!
4 Piece Nonmarring Scraper Set
Old 06-23-2013, 07:54 AM   #12
mapleton , Utah
Reinergirl is right about the cupped disc being best used on window frames and such, cleans beautifully. The type of disc I was referring to is a 3M radial disc 120 grit, white in color. This is a flat disc about 3/8 in thick that is used like a mini flapper wheel or wire wheel ie. you use the edge of the disc rather than the flat face. for areas with larger amounts of gunk to remove they can be ganged together 3 wide on a mandrel for about an inch of width. Fairly pricey at about $8 each but Kip recommends keeping the rpm's lower to prolong the life of the disc. Also, eye protection is a must since small pieces fly everywhere at high speed!
hope this helps
tim
Old 06-23-2013, 08:51 AM   #13
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Well folks, you do know I'm lurking even though I am unable at the time, to work on my GT. The information you seek is on page 31, post 427 of my thread below. Be aware that these little discs are kinda on the expensive side but do work wonderfully. They also like a RPM of around 15,000, to slow and nothing happens, to fast and they start coming apart. Those bristles really hurt when they hit you so a full face shield should be used.
Old 06-23-2013, 09:55 AM   #14
1999 25' Safari
Somewhere , Ohio
OMG, thanks so much to everyone! Especially to Kip for offering up his info and the link to the thread on his Globetrotter. I went there to follow his suggestion, page 31, post 427, but I couldn't stop there, I just kept reading and reading and............well, you get the picture! That thread is a wealth of information and I can't believe I somehow missed it before; I saved it to my faves and plan to go back here shortly to read more, starting at the beginning. (I'm was supposed to be out weedeating, then starting in on polishing again -- before the heat and humidity get up there again, but I've been reading here and I see it's already 93 degrees out there! I'm baddddd! DH was called in to work again and I'm fluffing off in the AC and not working. Oh well, a girl's gotta do what a girl's gotta do, right!? Just trying to get things lined up for future work -- for me, that is.)
I'm hoping we can make it to the Restoration Rally next year; I really wanted to this year, but it just didn't work out time-wise. Looking forward to meeting so many of our Forums members that I've been reading about and/or "talking" with here.
Many thanks again to all, and I'll come back to post how it worked out, but that will be a while, I have to finish polishing first before I get around to cleaning out the seams to make ready for the new sealant. Did I mention that I ordered five (5) of those 3M wheels Kip mentioned? Can't wait to get onto that part.
Deb
