Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 05-14-2008, 02:33 AM   #1
obxairstream
'69 Tradewind 25'
obxairstream's Avatar
Profile:  1969 25' Tradewind
Manteo , North Carolina
removing leak "fix" of PO (tar)
Th PO sealed the leaks arroung the roof with a liberal application of aluminum tape and roofing tar. any sugestions for removal? My thoughts go toward a torch or heat gun.
Jon
Workin' hard so I can play hard.
Jon
obxairstream is offline   Reply With Quote
Old 05-14-2008, 06:39 AM   #2
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Jon
Jon,
I would go the solvent route and NOT use any type of torch or heat gun. You will distort your aluminum with the heat!!!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 05-14-2008, 10:41 AM   #3
Excella CM
Excella CM's Avatar
Profile:  1978 31' Excella 500
Venice , California
On a really hot day you might be able to use a plastic scraper to remove the bulk of the softened tar and then follow-up with petroleum solvent.
"Not all who are lost are wondering" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-14-2008, 12:15 PM   #4
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
I agree with all of the above.
When you get to the solvent part, lay some old fabric down over the part you want to loosen and soak the fabric with solvent. This will concentrate it on the tar and help reduce evaporation.
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 05-15-2008, 04:32 AM   #5
obxairstream
'69 Tradewind 25'
too true
I started using a heat gun and a plastic scraper, and noticed quickly how the metal began to distort. So... the next question is... which solvent? I have some MEK (Methyl Ethyl Ketone) but that stuff is almost like using Plutonium in all the safety precautions you have to use.
Any suggestions on an aluminum safe solvent that will eat through 1 - 2 inches of roof tar (no exaggeration).
Jon
Old 05-15-2008, 04:36 AM   #6
obxairstream
'69 Tradewind 25'
666 posts?
Excella Cm
I don't know whether or not to take your advice considering your number of posts. At current reading you are at 666. Post another time so I'll feel a little better about heeding "the advice of the beast!"
Jon
Old 05-17-2008, 09:43 AM   #7
jacknshell
jacknshell's Avatar
Profile:  1963 24' Tradewind
north Rose , New York
hubby says gasoline or diesel fuel will disolve the roofing tar! will leave nasty coat which you will half to clean off after
jacknshell is offline   Reply With Quote
Old 05-17-2008, 02:08 PM   #8
Excella CM
Excella CM's Avatar
Venice , California
Paint thinner is a good solvent or kerosene. Gasoline is too volatile.
The way I see it, Jon, it's OK to have the number of the beast as long as the beast hasn't got yur number!
Old 05-17-2008, 02:22 PM   #9
Foiled Again
Foiled Again's Avatar
Virginia Beach , Virginia
Is there anything this stuff doesn't do?
WD-40 works well - but with the amount you have?
How wide an area did the PO cover with this evil mix? I agree the plastic scraper would be the place to start for the bulk of it. And you could use a hair dryer on MEDIUM heat... definitely nothing hotter. Possibly an OLD heating pad on medium too... use a layer of plastic film to prevent it from becoming one with the tar. (Bet the "leak" came from the A/C drain.)
GOOD LUCK you'll need it. Hi Ho Silver.
Paula
Today is a gift. That's why they call it "the present"
Old 05-17-2008, 02:40 PM   #10
n2916s
Profile:  1986 31' Sovereign
Miami , Florida
I had the very same problem and it came off using old terry towels soaked in mineral spirits. Lots of elbow grease as well.
I just can't imagine what he was thinking....
mike
Old 05-17-2008, 05:33 PM   #11
muddy_hollow
muddy_hollow's Avatar
Profile:  1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
aircraft stripper
best product out there for cleaning stuff from aluminum. Available at any local auto body supply shop.
Use it loads. Very pleased with the results.
Doug
65' Globetrotter 'The Otter'
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Fire(s) after the Dometic "fix"?? Kistler Refrigerators 1 08-11-2007 06:25 PM
Fix that "wrong" battery reading meter!! lebolewis Batteries, Univolts, Converters & Inverters 6 06-24-2006 07:44 AM
How can I fix "yellowed" bath fixtures? Wynne General Interior Topics 8 09-09-2004 08:50 PM
Shower "door" leak mcostanzo Airstream Motorhome Forums 1 08-11-2003 10:37 AM
