Th PO sealed the leaks arroung the roof with a liberal application of aluminum tape and roofing tar. any sugestions for removal? My thoughts go toward a torch or heat gun.
Jon
Workin' hard so I can play hard.
Jon
Jon
Jon,
I would go the solvent route and NOT use any type of torch or heat gun. You will distort your aluminum with the heat!!!
I agree with all of the above.
When you get to the solvent part, lay some old fabric down over the part you want to loosen and soak the fabric with solvent. This will concentrate it on the tar and help reduce evaporation.
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
I started using a heat gun and a plastic scraper, and noticed quickly how the metal began to distort. So... the next question is... which solvent? I have some MEK (Methyl Ethyl Ketone) but that stuff is almost like using Plutonium in all the safety precautions you have to use.
Any suggestions on an aluminum safe solvent that will eat through 1 - 2 inches of roof tar (no exaggeration).
Jon
Excella Cm
I don't know whether or not to take your advice considering your number of posts. At current reading you are at 666. Post another time so I'll feel a little better about heeding "the advice of the beast!"
Jon
How wide an area did the PO cover with this evil mix? I agree the plastic scraper would be the place to start for the bulk of it. And you could use a hair dryer on MEDIUM heat... definitely nothing hotter. Possibly an OLD heating pad on medium too... use a layer of plastic film to prevent it from becoming one with the tar. (Bet the "leak" came from the A/C drain.)
GOOD LUCK you'll need it. Hi Ho Silver.
Paula
Today is a gift. That's why they call it "the present"
