Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 05-26-2008, 12:19 PM   #1
airgirl
Airgirl
Profile:  1965 22' Safari
St. Louis , Missouri
Remove Propane tanks and replace window gaskets
Hello,
I have a '65 Safari.
How do I remove the propane tanks?
Please confirm what the propane tanks were used for? Was it stove, fridge and heat?
How do I replace the window gaskets?
Any adivice on replacing door weather stripping?
Thank you.
airgirl is offline   Reply With Quote
Old 05-26-2008, 12:43 PM   #2
vinstream
Commercial Vendor
vinstream's Avatar
Profile:  1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
golden , Colorado
(turn gas off) To remove tanks is easy but should be done with extream care as to not crimp the gas lines... Always use two wrenches on each fittings so that the lines do not get rotated and bend! Then undo the large fly nut on top of the rod that runs from the bottom of tanks to the top. I bet this is rusted in place, most are... so penatrating oil is a must.
If your tanks are orginal they are out of date and should be replaced!
The tanks are use to run all, the stove. frig. heat. (this age of trailer all should be serviced by a RV shop)
Window gaskets are again easy to do but extream care should be used as to not break the frame at corners and glass. My bet is because of the age that the glass will break!... The new parts can be found at "Vintage trailer supply"
or a glass shop (but not always).
Door weather strip agian is easy to replace... But make sure door is i great working order... make sure it is not bent or have lose parts inside. I have found that new seals if done wrong will damage the door... so take your time and trim as needed!
http://www.VinStream.com
"Redesigning Life & Road To Vintage Custom Trailers"
vinstream is offline   Reply With Quote
Old 05-26-2008, 01:01 PM   #3
Jim Foster
Jim Foster
Jim Foster's Avatar
Profile:  1965 17' Caravel
Walnut Grove , California
If your tanks have old style valves, and old style lines, the nut that holds the tubes to the tanks is LEFT hand thread.
If it has new style valves, and the old lines were used and threaded inside the valves, they are still LEFT hand thread.
If it has new style valves and new style lines, there will be a large nut on the outside of the valve attaching the lines which you can undo by hand, RIGHT hand thread.
Old 05-26-2008, 01:53 PM   #4
airgirl
Airgirl
I am a novice. How do you turn on the gas or verify the tanks are empty and safe to remove. What do I do with the connection to the trailer?
What do you mean the glass will break? Leaking is occuring so they need to be repaired so I can put in my new floor.
Old 05-26-2008, 04:23 PM   #5
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Check this link out, it may help
Weather Strip Maintenance
'74 Overlander (Rear Bed)
'77 20' Argosy MH (Looking for a new home)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281 w)
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 05-27-2008, 09:48 PM   #6
Aage
Profile:  Currently Looking...
Aurora , Ontario
FYI: at the time of this post, your site was down.
Aage is online now   Reply With Quote
Window Gaskets Robin Stone Windows & Screens 6 03-06-2008 04:11 PM
Window gaskets? rebel beck Windows & Screens 9 09-12-2006 01:22 PM
Remove, or Replace? Chuck Jacks, Stabilizers, Lifting and Leveling 13 04-13-2006 07:59 AM
how do you remove the gas tanks? jlandau LP Gas, Piping, Tanks & Regulators 5 03-12-2006 02:16 PM
Remove all Propane items...and replace with all electric leefields LP Gas, Piping, Tanks & Regulators 19 02-20-2006 05:57 PM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
