Old 06-21-2011, 01:32 PM   #1
1973 31' Sovereign
Portland , Oregon
Images: 22
RemovAll 220 - will it remove old caulk?
I have read quite a bit in the forum about RemovAll 220 being a great product for removing old clear coat. What I am wondering is will it also help with removing old Vulkem and old Silicone caulking. I have found that Jasco paint remover does loosen up old caulk and make it a lot easier to remove. It also attacks the clear coat in the area where you apply it to a joint. It is not particularly pleasant stuff to work with though. I would especially like to clean out the gloppy old caulk put on by a previous owner so that I can reseal these joints. I would like to remove my old clear coat as well at some point. So my question is really in two parts as follows:
1.) If I want to go ahead and strip the clear coat now can I also get some help from RemovAll in cleaning up the old caulk?
2.) If I decide to wait until later to remove my old clear coat with RemovAll will it also attack the new caulk that I put in now?
The bottom line question is will RemovAll loosen old Vulkem and/or Silicone caulk?
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
Old 06-21-2011, 02:00 PM   #2
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Remove all works great for the clear coat. Silicone caulk remover from Vintage Trailer Supply is about one of the only products that works. The PO of our 65 Safari must have thought that all problems could be solve with silicone caulk. It took us 2 and a half days of hard work to remove it all.
Good luck!
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 06-21-2011, 08:26 PM   #3
1973 31' Sovereign
Portland , Oregon
Images: 22
Good luck!
Did the caulk remover that you mentioned also attack the clear coat? If you don't mind taking the clear coat off at the same time Jasco paint remover works better than anything I have tried to date. It also does its job in minutes rather than hours. I was hoping that RemovAll - also being a paint remover - might work as well as Jasco on caulk. I like the non-toxic nature of RemovAll and the water clean up too.
Malcolm
Removing exterior caulk RottenRick Cleaning, Stripping & Polishing 5 10-24-2013 05:07 AM
How to remove swirls?anyone can tell me what is the best technique for removing the m Astriking Cleaning, Stripping & Polishing 17 08-08-2011 08:07 PM
How to remove slip hub / flange 1970 3/4 bath silversafari Waste Systems, Tanks & Totes 2 02-27-2011 07:40 AM
How to remove door from trailer? nm1oqrz Doors & Locks 2 02-16-2011 07:57 PM
Before I remove bath end cap Breadbug Ribs, Skins & Rivets 3 01-27-2011 01:03 PM
