Old 09-12-2011, 08:07 PM   #1
North Fayston , Vermont
rear gutter
We have a 1963 Globetrotter we are redoing. . When it rains, we get rain in the rear around the window. AT first we thought it came from the window itself, since the window is just taped in. We now believe it is leaking from the gutter. So, should we take the gutter off and reseal it with Butyl tape. IF so, that means we will drill out the rivets and then replace them with Olympic Rivets, since the inside walls are in place? OR, should we clean out the area and reseal the edges with Vulkum. OR, do something else?
northfayston is offline   Reply With Quote
Old 09-12-2011, 08:11 PM   #2
You might also check the clearance lights for leaks.
Old 09-12-2011, 08:13 PM   #3
I should have also added to make sure the window gasket is fresh and alive.
Rear End Separation Permanent Fix? dmand001 Repairing/Replacing Floor &/or Frame 23 07-24-2017 02:12 PM
How does my rear end look? desertair27 Repairing/Replacing Floor &/or Frame 35 02-23-2013 11:24 PM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Leak appears when trailer rear jacked up HCR Fresh Water Systems 20 04-06-2011 04:50 PM
