Old 11-10-2015, 09:30 AM   #1
2006 28' International CCD
Germantown , Tennessee
Rear End Gap - Sealing over Trempro 635 with Eternabond
I've sealed up the gap under the rub rail at the back of my trailer with Trempro 635 now. And although I'm replacing the rotten plywood at the rear with Coosa Bluewater 20 board I want to do my best to make sure it doesn't leak from the rear again. (Without having to weld or use a torch.) So, before I reattach the rub rail I'm thinking about taking some of the aluminum eternabond tape I have and putting that over the area where I caulked with the Trempro.
Is there any reason that I should not do this? I don't want to hurt the caulk job, but it seems to me the eternabond would give an extra layer of protection in the event the caulk job began to leak.
jami20 is offline   Reply With Quote
TremPro 635 vs. Loctite PL S-40 OffTheCouch Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-29-2015 11:14 AM
TremPro 635 -vs- OCI QUAD -vs- OCI H2U grndslm Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 05-19-2015 07:33 PM
Alternatives to Trempro-635 perryg114 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 12-12-2014 01:31 PM
Trempro 635 TravisA Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 10-05-2014 05:38 PM
Rear end gap Bobz Hog Repairing/Replacing Floor &/or Frame 8 11-15-2007 06:43 AM
