Old 01-25-2012, 12:39 PM   #1
HCR
HCR's Avatar
Livingston , Full time traveler
Rain leaking from Air Conditioner
Had 40mph winds and about 7 inches of rain last night near Bastrop, Tx. Woke up to find water leaking heavily from AC (DuoTherm Penguin).
Previously replaced cracked pan and added gasket (which was missing). Doesn't leak w/ rain and no wind.
Suggestions for cause and repair?
Airstream of Consciousness
HCR is offline   Reply With Quote
Old 01-25-2012, 12:50 PM   #2
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
I would look at the drain tube from the pan. It doesn't take much to clog it or slow it down. Usually blowing a little air up the tube will clear it if that is the problem
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 01-25-2012, 01:56 PM   #3
Sneakinup's Avatar
1977 31' Sovereign
Tampa Bay , ^
Images: 118
I had the same problem after installing a new AC in my last AS. After a few weeks, the AC had settled in on the gasket and it simply needed a few more cranks on the screws that tighten the AC down to the trailer. That worked for me, hope it helps.
My 77 Sovereign Renovation
Out in the woods, or in the city, It's all the same to me.
When I'm drivin' free, the world's my home....When I'm mobile.
Sneakinup is offline   Reply With Quote
Old 01-25-2012, 03:08 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I had the same issue when I installed a new AC unit. That was several years ago and it has not leaked since.
Richard
Old 01-25-2012, 05:30 PM   #5
1972 21' Globetrotter
nc , North Carolina
what sneakinup said
rock60 is offline   Reply With Quote
Advice Needed: Duo Therm Air Conditioner & Heat Pump BKBroiler67 Furnaces, Heaters, Fireplaces & Air Conditioning 19 07-22-2015 05:40 AM
Removing privacy curtain so air conditioner can be removed saltrm1 Furnaces, Heaters, Fireplaces & Air Conditioning 5 04-11-2013 05:26 PM
Dash Air Conditioner Problems Santart Land Yacht/Legacy Motorhomes 4 09-05-2012 01:54 AM
Air conditioner cover havec1 Roof Vents, Skylights & Fans 4 08-12-2011 09:35 AM
need air conditioner ally 1966 Overlander 2 07-02-2011 09:54 PM
