Old 03-18-2003, 08:50 PM   #1
mvbuster's Avatar
1987 25' Sovereign
Shelton , Washington
Rivet rain leak
I can't locate the source of a leak. I find water in the roadside rear storage locker of our 1987 25 Sovereign, after a heavy rain. I've caulked everywhere I can imagine the water source could be . It gets wet right under the light on the floor of the compartment, just aft of the locker door. I tarped the top of the trailer, and it didn't stop. Any body else ever had this problem ? Any Ideas ?
Neil
mvbuster is offline   Reply With Quote
Old 03-18-2003, 09:10 PM   #2
I had a leak in the same place that was caused by a poorly fitted gasket around the storage compartment door.
Mark
Old 03-19-2003, 10:37 AM   #3
Check the sewer vent pipe gaskets for both the gray and black water. You will have to remove the polished 3 x 5 vents covers to inspect the gaskets.
inlandrv.com
airstreamparts.com
airstreamcandy.com
intermittent water leak drcharles2 Plumbing - Systems & Fixtures 2 01-22-2004 10:32 AM
Fresh water leak - help wayner1239 Fresh Water Systems 6 10-01-2003 02:20 PM
My leak has returned Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 12 08-12-2003 06:44 AM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
Rainwater leak James Schmidt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-11-2002 06:28 AM
