Old 10-21-2011, 05:18 PM   #1
CowtwnSilver's Avatar
2004 19' Bambi
Fort Worth , Texas
Rain Leak 2004 Bambi
Noticed the alum back splash behind the stove on my 2004 Bambi was dripping water during a rain storm. I suspect it is the oven vents on the exterior. Anyone suggest a plan of action?
CowtwnSilver is offline   Reply With Quote
Old 10-21-2011, 05:26 PM   #2
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Should be pretty easy to check and re-caulk if found necessary.
I just put a new plastic vent on ours recently because the old one was damaged - if I recall, it just went on with butyl tape behind it - no leaks so far. If you found what looked like an entry point for a leak, caulking with Sikkaflex or Acry-R should do the trick. Maybe try spraying water on it?
On the other hand leaks can be deceptive. What else is close to being in line with the leak? AC unit? Fantastic fan? could also be the source.
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
A/C leak only with sideways rain Bowmans Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 10-07-2011 10:47 AM
Rosco :: 2004 International CCD Bambi Grizzly6 Airstream Registry Discussions 0 08-19-2011 08:31 AM
Interior Light 2004 Bambi CowtwnSilver Lights - Interior & Exterior 3 05-11-2011 07:49 PM
Roof Leak during heavy rain andyfuson Leaks - Weatherstrips, Gaskets, Caulks & Sealants 12 03-21-2011 12:33 PM
2004 Airstream International CCD 16' Bambi eBay Watch Airstreams on eBay 0 03-06-2011 05:00 PM
