Old 05-09-2019, 05:50 AM   #1
Hampshire , Illinois
Proper Sealant Caulking
What is the best product to use on exterior band (Midway down the side and just above the floor). I am referring to the two mental rap-around bands around the outside of the camper. There must be a sealant for a caulking gun to apply to the top of these band to avoid water from seeping down into these areas.
debfm is offline   Reply With Quote
Old 05-09-2019, 07:13 AM   #2
1972 25' Tradewind
1976 31' Excella 500
Denver , Colorado
http://beahmstream.com/all-kinds-of-...-leak-sealers/
25' 1972 Airstream Trade Wind Land Yacht
2006 Jeep Liberty CRD (diesel)
http://BeahmStream.com
kidjedi is offline   Reply With Quote
Old 05-09-2019, 09:12 AM   #3
1971 27' Overlander
Kansas City , Kansas
Sikaflex polyurethane works great
Shermy1987 is offline   Reply With Quote
Old 05-09-2019, 10:38 AM   #4
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
I'm using Lexel sealant.
It is a permanent solution.
Old 05-11-2019, 05:52 PM   #5
1971 27' Overlander
Lexel is a great sealant but you can't get it in grey and dirt slowley turns it black.
Old 05-11-2019, 08:39 PM   #6
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Going on a few years without a wash and mine is still crystal clear where you can actually see it!
Old 05-11-2019, 08:39 PM   #7
1970 27' Overlander
Poteau , Oklahoma
No Lexel is not a permanent solution, don't fall for the marketing hype.. There is no such thing I am afraid. Im right in the middle of fixing leaks on my house that has a metal roof that had lexel applied 11yrs ago and now it leaks like a sieve in about 5 places.
cowdiddly is offline   Reply With Quote
Old 05-11-2019, 08:52 PM   #8
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Must be an application failure...
Others here report great success with the stuff, including my 20 year old galvalum roof at nearly 13000 feet in Colorado.
Works great on my Airstream as well. Success over the long term isn't marketing hype!
I do wish it came in a metal color...
Old 05-12-2019, 08:45 AM   #9
1971 27' Overlander
Sealants fail from poor application 99% of the time. I used Lexel to seal my sky windows. It is a fantastic sealant that will last for years if applied correctly.
Sealant question (But not your normal caulking debate!) drodio General Repair Forum 9 10-10-2016 05:38 PM
Caulking Kistler Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 04-19-2003 12:32 PM
Sealing Windows & Caulking outside mgordon Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 01-13-2003 12:18 PM
Furnace Exhause Plate Caulking niftypkg Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-23-2002 07:32 PM
caulking ALANSD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 07-10-2002 02:13 AM
