Old 04-19-2011, 11:23 AM   #1
Severna Park , Maryland
Problem Avoidance Maintenance
Have only been in Airstreaming a few years and recently bought a new 28' Flying Cloud. These forums certainly are shortening my learning curve; but, shudder when I read all the leak issues.
Does anyone have a maintence schedule for re-caulking around windows, belt line moulding, etc. that prevents these problems before happening? For example, following a tip from an experienced owner, last Fall, I applied butyl rubber backed foil tape on top of the caulk on the roof penetrations to stop or slow down the inevitable uv deterioration of the caulking. On non-leaking windows, does anyone re-caulk for prevention?
Any other ideas in this area would be appreciated.
sailorii is offline   Reply With Quote
Old 04-19-2011, 12:34 PM   #2
2010 27' FB Classic
N/A , Texas
If you check your seals and caulk a couple of times a year there should be no leak issues. Recaulk only when, and where, needed.
Old 04-19-2011, 01:42 PM   #3
jackson center , Ohio
The key is to check on a regular basis that works for you(at least twice a year). Sealant on top of sealant does not always help as the sealants will have a build up of dirt and grime that can prevent bonding. If an area shows signs of cracking or a hole is visible ;it is better to remove old sealant then clean area with alcohol and reseal with any good exterior sealant with UV inhibitors.
Schu is offline   Reply With Quote
Outlook express problem Castaway Computers, Internet & Satellite 8 04-07-2011 02:11 PM
Barker Super Jack Problem Luckyducks Jacks, Stabilizers, Lifting and Leveling 1 03-20-2011 08:49 AM
