Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 08-27-2009, 03:27 PM   #1
fatwgn's Avatar
1965 20' Globetrotter
Janesville , Wisconsin
Problem area in rear of 1964 Tradewind
I am in the start of a floor replacement in a 64 Tradewind -- the rear area of the floor is soft in a few spots and has some soft spots elsewere in the floor --- My question is that in the rear of a tradewind there is a storage area between the bumper and the body - the bellypan extends all the way to the bumper and there is a aluminum cover with a hinge on it that covers the area between the bumper and body - if I reach up under that cover I can feel the plywood floor - Is this a problem area ??? what seals the water from just weeping up from the aluminum cover to the wood???
has anyone had issues with this area ???
Next leak question is how and what to seal seams with once a leak is found ? do you seal it from the outside and inside or just outside?? - I will have the rest of the interior panels off this weekend and thought that i would seal the leaks before installing the floor ..
Thanks in advance for any help and advice
Scott
fatwgn is offline   Reply With Quote
Old 08-27-2009, 04:48 PM   #2
Hi Scott, and welcome to the forum!
The rear of our '64s is a problem in that the water seeps into the floor, but It's more from the frame than from the hatch. You should put a good bead of Vulkem at the frame to shell junction to stop water from getting in there. On my safari the rear of the shell didn't cover the plywood edge at the back all of the way down. It only covered about half of it. When you take the bumper cover and belt trim off of the rear end you may find the same thing. I will probably be re-engineering the cover for the rear hatch on mine. It's a hard thing to seal, with the way they built it. If you can't make the changes to the rear end you should go to lengths to waterproof your new flooring material. That doesn't mean you should use plastic or metal. It lasted 45 years with totally unprotected wood anyway. I used water-based wood floor finish on the bottom, and Kilz primer and exterior latex housepaint on the edges and in a few inches on the top surface. This, in addition to the better sealing of obvious leak-prone areas, will increase the life of my floor greatly.
There are a few good seam sealers out there. I rely on parbond for exterior seam sealing. It comes in an aluminum color. If you have panels removed, you should use Vulkem when you reattach them to each other. It's harder to use, but it's great stuff for this application. The Parbond is easier to fill existing seams with, as it's not as stiff. Check out Vintagetrailersupply.com and if you're not sure if you have the right things call them & tell them what you are doing. They are very helpful.
Also check out Prodex insulation at insulation4less.com . I just reinsulated with this stuff, and it's great to work with. No fiberglass mouse house anymore! It made a big difference in the insulation effectiveness. I heard about this from Uwe at Area63productions.com. He's a master. Check out his work if you have a chance.
I'm going to give it the ultimate test in two days, at Burningman. Last year it was 107 degrees when I arrived. We'll have to wait and see what it's like this year!
Good luck with your project.
Rich
VIKING is offline   Reply With Quote
Old 08-29-2009, 08:36 AM   #3
fatwgn's Avatar
Thanks for the help Viking --- I sent you a pm
Scott
1964, 1964 tradewind
1961 0r 1964 Tradewind ???? jbsails Title, VIN & Registration 25 03-01-2011 10:38 AM
1964 Tradewind w/Baybreeze AC Unit perrynik Furnaces, Heaters, Fireplaces & Air Conditioning 16 06-02-2009 04:13 PM
body work on 1964 Tradewind caguido General Repair Forum 0 10-14-2008 04:12 PM
1964 Tradewind Fishbone 1959-69 Tradewind 11 07-13-2008 09:23 PM
tradewind window 1964 frazer45 Windows & Screens 2 01-18-2005 10:45 AM
