Old 04-24-2009, 01:37 PM   #1
digger bear's Avatar
1973 23' Safari
pressure test results & sealer
While at the Dogwoods & Bluegrass rally, I asked SoldierMedic to pressure test my rig. As most of you know, it is a process where he installs a fan contraption to put added air pressure in your unit and sprays soapy water on the outside to find leaks. They show up as bubbles.
Trust me, at a rally, it always draws a crowd.
After seeing a few other members units being tested – including a fairly new one –looking like a frothing mad dogs, I was pretty concerned. Turns out I had two leaks of substance.
One under a window here:
One where the plug was installed. No sealer - one of the many reasons I will never use that repair shop again…
Most of my rig looked like this – remember it is a 73 that is left outside all year long: No bubbles.
The one thing I did differently was to use Capt. Tolley's Creeping Crack Cure everywhere – It is a thin substance that pulls into seams by capillary action. You will have to do many applications of it and, if left to dry it is a buggar to clean off so stand by with a moist towel to catch drips. It even goes into horizontal seams.
I don’t own stock in the company but sure wish I did. You might give it a whirl...
Digger Bear
Non impediti ratione cogitationis
digger bear is offline   Reply With Quote
Old 04-24-2009, 02:11 PM   #2
soldiermedic's Avatar
Florissant , USA
Hey Digger,
I wish we had a before testing of your trailer to compare how well that creeping crack gunk works, but looks like it did the job well.
Don't forget that both of your sewer vent gaskets are in need of replacement and can let water leak in due to their current condition.
Steve
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 04-24-2009, 06:26 PM   #3
Roadtrain O--O~(--ooo--)
ebair's Avatar
2000 34' Limited
1979 31' Excella 500
Miamisburg , Ohio
Another example
After seeing the results you had I also had perform his magic on my 34'. I'm glad he did as the process exposed a number of leaks. Almost all of the rivets holding the Zip-Dee awnings were of the hollow type and almost all were leaking, there were also leaks at the front window and where a bit of the molding had loosened at the rear of the wheel well.
At Steves reccomendation, I picked up some Par Bond and will be spending a beautiful Saturday sealing up my coach, Makes me feel better knowing what needs to be done (and where!) Thanks Steve! and sign me up for a once a year preventitive maintenance appointment.
ID:	79209   Click image for larger version
'00 34' Classic Limited (LOVSHAC)
'12 3500HD, 4x4 LBZ D/A CC LB
AIR #12881
TAC OH-10
ebair is offline   Reply With Quote
Old 08-22-2009, 09:56 AM   #4
san luis obispo , California
What type of soap and what mix ratio.
zues is offline   Reply With Quote
Old 08-22-2009, 07:12 PM   #5
Florissant , USA
Any type of soap will work. Use a ratio that suds up when shaken.
Old 08-22-2009, 08:46 PM   #6
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Steve,
sure wish you'd live closer!! Love to try that out on both our rigs and find what we have.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 08-23-2009, 09:35 AM   #7
Florissant , USA
Tell ya what Scott,
Host a big rally up in your neck of the woos, and if enough people want the testing I will fly up there and join the group.
Steve
Old 08-23-2009, 09:42 AM   #8
1962 28' Ambassador
1962 30' Sovereign
Webster Groves , Missouri
Steve, can I help you drag your stuff to the 50th C2C? Hosting Pee Wee I know you are cramped for space. I would really like to get a before leak test on my Tar Baby!
Originally Posted by soldiermedic View Post
Tell ya what Scott,
Steve
Xbob2 is offline   Reply With Quote
Insulation - real test results... malconium Exterior Restoration Forum 40 03-15-2008 11:36 AM
Polish & Sealer PolishGuy Commercial Listings 0 08-08-2005 01:24 PM
Matchless VL100 test results and photos- TravelCloud Cleaning, Stripping & Polishing 10 06-24-2005 12:02 PM
Metal Gloss polish & sealer LeeA Cleaning, Stripping & Polishing 15 11-26-2003 10:02 AM
Tire pressure & towing kooblekidz Airstream Motorhome Forums 4 04-28-2003 12:34 PM
