Old 08-09-2005, 11:45 PM   #1
VAC President
Buttercup's Avatar
1977 27' Overlander
1954 25' Cruiser
1990 34.5' Airstream 345
VC Highlands , Nevada
Send a message via Skype™ to Buttercup
Plumbers Putty
Good for plumbing not good to seal AIRSTREAM windows with! PO sealed the windows and practically everything else with plumbers putty. When that failed PO followed up with liberal amounts of some sort of hardening calk. We found a dozen leaks in our TT after a heavy rainstorm. At least we know where the leaks are coming from.
We are in the process of removing the offending material and replacing it with the good stuff VULKEM. It is working. The areas we sealed do not leak now. Simple!
Pictures to follow.....
Buttercup's Web Site. WBCCI #17330, 11281 & 7830. VAC Past President, TAC NV-2 & NV-3
Buttercup is offline   Reply With Quote
Old 08-10-2005, 02:36 AM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I hope it is easier to remove than sillycone, one of my PO's must have gotten the case load price on the stuff and to add insult to injury it was silver it takes most of a day to clean off around a single window to get it to the point that it can be resealed.
Aaron
WBCCI #XXXX AIR #2495
Old 08-10-2005, 04:29 AM   #3
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Funny...Wally thought plumbers putty was just fine on our 59. The only leaks I have are on the front and rear end windows where there was extenuating circumstances. Good stuff. Still pliable after 40+ years.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 08-10-2005, 09:51 AM   #4
desi arnaz's Avatar
where can you get vulchem?
desi arnaz is offline   Reply With Quote
Old 08-10-2005, 01:09 PM   #5
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
You can get Vulkem from Airstream inc, Inland RV, Airstream Dreams and many other places including RV parts places. These 3 happen to have websites.
AirForums Custom Search
Janet H is online now   Reply With Quote
Old 08-10-2005, 02:26 PM   #6
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by 59toaster
Funny...Wally thought plumbers putty was just fine on our 59...Good stuff. Still pliable after 40+ years.
Are you sure you're not looking at RV putty? I had not seen the stuff until I got my Airstream, but RV putty appears to be different than plumbers putty in that it is not as oily, and it does not pull apart as easily.
Not that any of my post makes that much difference in the grand scheme, but I felt inclined to toss out another material possibility.
Tom
Old 08-10-2005, 02:28 PM   #7
TomW's Avatar
1967 26' Overlander
Possible local source
Originally Posted by Janet
You can get Vulkem from...
Someone mentioned Sherwin Williams paint store before. I have not verified it though. Get Lucy to run down there...
Tom
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Airstreams in winter?? Curtis-79MH Airstream Motorhome Forums 6 03-27-2006 12:58 PM
Shower drain seal Safari Tim Waste Systems, Tanks & Totes 6 08-15-2004 11:18 PM
Univolt reminder ** Battery Check! Sav'h Steve Batteries, Univolts, Converters & Inverters 21 10-07-2003 02:18 PM
Plumbers, and those w/ plumbing experience: Chuck Our Community 1 02-15-2003 06:54 AM
