Old 02-20-2011, 04:55 PM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
picture of D gasket
Does anyone have a closeup pic of a Dstyle gasket installed on a 60's Airstream Hehr window?
bwaysteve is offline   Reply With Quote
Old 02-20-2011, 05:12 PM   #2
reinergirl's Avatar
Hollis , New Hampshire
like this one from vintage trailer supply?
Hehr Standard Backframe Gasket or
Hehr Standard Glass Seal
reinergirl is offline   Reply With Quote
Old 02-20-2011, 05:23 PM   #3
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
No, this is a plain D shaped gasket they sell at Inland
Old 02-20-2011, 07:52 PM   #4
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
I'm sure you can find it on the web site.
I found this site helpful in restoring Hehr windows. Restoration Topics - Window Repairs
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 02-20-2011, 09:43 PM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Seals and Gaskets - Manufacturer
or, come over here...I have some.
Old 02-20-2011, 10:39 PM   #6
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
have some
I have some,but I will call when I am in Gainseville manana.
Old 02-21-2011, 01:19 AM   #7
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
D shape
I just installed them on my 58 fc. I am very pleased with the results. I used a bigger d shaped gasket then inland sells and it fits the space very well.
I will try to get you a picture tomorrow.
Matt
ddstech is offline   Reply With Quote
Old 02-21-2011, 11:01 AM   #8
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Matt,
You changed your name? Where'd you get the larger D gasket?
SilverHoot is offline   Reply With Quote
Old 02-21-2011, 02:15 PM   #9
ddstech's Avatar
Folsom , California
There is a great trailer supply store in Sacramento with an assortment of sizes of gaskets. It's about .60 a foot.
Yes I changed my name, no particular reason.
Old 02-21-2011, 08:56 PM   #10
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Matt
This may be hard to explain.My 65 windows are flat glass with frame.It is my understanding that I attach the D gasket to the window itself.
On 60's models I am hearing you only do 2 sides and bottom,but need clarification.
I don't want to glue on incorrectly.
There is a lip on the window and the D fits on the lip sideways,meaning if you were looking at the window installed the oval side of the gasket is facing to the sides and down to the bottom.I assume this is correct as the edge surface is not wide enough to glue all down.If anyone has done this on a 60's model chime in .Thanks.
Old 02-21-2011, 09:36 PM   #11
ddstech's Avatar
Folsom , California
windows
We do have different windows. So my pictures will not help you. But I know how everyone loves pictures so I will post anyways! I had the rivot on gasket, which needed to be replaced but I am not about to pull my windows out, replace gasket and rivot them back on. So I cut the old ones out with a razor knife, sealed the edges with par-bond, and glued the new D shaped gasket on where the old gasket used to be. It created a very nice seal.
Sorry this does not apply to you, however I know there are others that may be interested.
ID:	122848   Click image for larger version
Old 02-21-2011, 09:49 PM   #12
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Did you do yours on the top?
Old 02-22-2011, 12:32 AM   #13
ddstech's Avatar
Folsom , California
There was no gasket on the top, so no, I just replaced what was there.
Old 02-22-2011, 09:23 AM   #14
1961 24' Tradewind
Stevensville , Montana
Check out McMaster-Carr on the net, they carry a ton of different gaskets and cheaper than most places.
WadenMichell is offline   Reply With Quote
2011 Superduty Picture Thread... THEPILL Tow Vehicles 79 07-08-2011 03:55 PM
Exterior gasket material? NicheVintage Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 01-31-2011 08:56 PM
Will gasket material seal the rear bumper storage? tvanwave Bumpers & Bumper Storage 0 01-31-2011 04:00 PM
Gasket source for Suburban NT30K furnace? nickcrowhurst Furnaces, Heaters, Fireplaces & Air Conditioning 5 01-13-2011 01:35 PM
Part # Duo therm penguin gasket? HCR Furnaces, Heaters, Fireplaces & Air Conditioning 0 01-09-2011 12:27 PM
