Old 01-30-2012, 01:36 PM   #1
2004 16' International CCD
Orem , Utah
Picked up some sealant at Airstream dealer
Sikaflex 1a in aluminum and AcryL-R sm5504 narrow joint sealant in aluminum. Will these products work for above banana wrap area. There is chrome strip that is removable right above that where shell meets there are areas the old caulk is not doing it's job. Should I consider doing this area over. I can get parabond local as well. I asked for 271 sikaflex told me they have lots of it but gave me 1a sikaflex guess they do not know what there talking about. I will submit photo shortly.
starcraft is offline   Reply With Quote
Old 01-30-2012, 02:36 PM   #2
Orem , Utah
ok here are some pictures
overall trailer looks pretty nice
ID:	149893   Click image for larger version
ID:	149895   Click image for larger version
Old 01-30-2012, 03:28 PM   #3
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up What I have used...
I got the "Plews" gun to apply the acryl-r clear on all the narrow gap seams...
Used the Loctite PL,sika 721uv and parbond on the large gap applications.
Name:	small_Acryl-R 16oz Can.jpg
ID:	149907   Click image for larger version
ID:	149910   Click image for larger version
Name:	SOLAR PANELS; ROOF LEAK 021.jpg
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 01-30-2012, 07:51 PM   #4
Orem , Utah
Is this a bad area to have leaking?
Parabond had video of these areas using aluminum color and alcohol on rag. I caulked many new homes so I am pretty much caulkmaster. For me to try and remove all old caulk seems extreem for my new trailer looks like grey rubber product in there failing. Would parabond grip around this stuff.
Old 01-30-2012, 08:14 PM   #5
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Sealants
Hi Starcraft,
Yes you should re seal anything that looks like it is not properly sealed. Especially the bumper trunk flashing under the "rub rail" at the back of the trailer. If not it will funnel water under the trim and directly into your wood floor. You can't see it until it is usually too late.
Here's what it looks like from below.
Lance
Top is offline   Reply With Quote
Old 01-31-2012, 05:44 AM   #6
Thumbs up
Star,
No caulkmaster here......
I used the black Loctite PL on the blacktank vent on the roof...still holding up very well after 5 Seasons. When it came time to seal the rear bumper leak,(same as above), thats what I used, above and below the molding, doesn't blend as well as the alum color would but......we'll see how it holds up.
I didn't clean "all" the old, just used a small hooked awl & cleaned out as much of the loose stuff as I could, blew out and wiped down with mineral spirits.
I have some panel and clearance light leaks that I have to re-do this Spring and will be using the plews gun & acryl-r for those.
ID:	149944   Click image for larger version
PFC
"Tahawus"
RLC
John Prine
Old 01-31-2012, 07:05 AM   #7
1981 31' Excella II
New Market , Alabama
I would say you need to use the Silkaflex or Tempro 635 on that belly band. The gray cracked stuff is probably Parbond. I don't see much of any sealant on that belly band. That area above the bumper plate and below the belly band really needs to be sealed well. It is worth removing the belly band just to be able to seal and inspect that area. Make sure your floor is not already rotten back there. I expect 90% of trailers leak back there. The Silka Flex is for around window frames etc where there is little or no gap.
There needs to be a pretty good fillet of material or it will crack around that belly band. The more material the less it has to elongate when something moves.
Perry
Old 01-31-2012, 08:32 PM   #8
1975 31' Sovereign
Valparaiso , Indiana
We have just purchased a '75 Sovereign 31 with a center bath and we are having the same problems with leaks. We have removed all built-ins in the front and rear and discovered the floor is rotted at the rear with isolated water damage in the front. I am assuming our next step is to take out all the old caulk around the windows and door and recaulk everything. What material should be use around the windows and door and what is the best way to remove all of the old caulking without damaging the skin?
Is it necessary to remove the belly band and inspect behind or should we just caulk? Should we use the Silkaflex or Tempro 635?
boilermaker is offline   Reply With Quote
Old 01-31-2012, 08:56 PM   #9
Arrow
28430w-01 Acryl-R SM5504 is a one component, acrylic self leveling compound designed to seal mechanically fixed joints.
Would be much harder to use Sika for closed gap seams.
I've tried.
PFC
"Tahawus"
RLC
John Prine
Old 01-31-2012, 09:17 PM   #10
Central , Mississippi
on my last 3 Airstreams I have come to 1 conclusion...blue tape and Tempro...
That stuff stay flexible for years...all of the other stuff I have used gets hard and cracks...leaks soon to follow...
Mask off both sides with blue tape (it matches the Airstream quite well)...shoot a bead of Tempro and shove..um. smooth...into the crack with a finger...
leaks b gone
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
HiHoAgRV is online now   Reply With Quote
Old 02-01-2012, 06:47 AM   #11
1975 31' Sovereign
Thanks for the info. What is the best way to remove the old caulk. I have tried a utility knife and a painters tool but I'm afraid it will damage the skin.
Boilermaker
Old 02-01-2012, 07:10 AM   #12
Thumbs up
Carefully...
I use a plastic putty knife/scrapper. Mineral spirits, Black Majic,(used to be whestlies), Bleche-Wite Tire Cleaner, Lectra Motive spray clean. Plenty of rags and gloves.
Worked pretty good on the roof vent.
Name:	SOLAR PANELS; ROOF LEAK 019.jpg
ID:	149988   Click image for larger version
Name:	SOLAR PANELS; ROOF LEAK 011.jpg
PFC
"Tahawus"
RLC
John Prine
Old 02-01-2012, 10:11 AM   #13
Orem , Utah
How about brake cleaner
It is used on automotive applications because it leaves no residue. Do not use carb cleaner that stuff is strong.
Old 02-01-2012, 10:32 AM   #14
Question
I have used brake cleaner....very very carefully. Tested in several areas not visible. I did not list it because I don't recall the brand. It's not something I'd recommend. Some are VERYstrong and will damage the clear. Never sprayed directly on anything, had some road stripping paint on the banana wrap, only time I ever used it.
PFC
"Tahawus"
RLC
John Prine
Airstream Rental for Airstream Owners ONLY jverduzco Airstream Lifestyle 34 12-26-2012 12:18 PM
06 Airstream Safari 23, Airstream, Airstream Flying Cloud, Airstream Camper, RV eBay Watch Airstreams on eBay 0 10-10-2011 08:50 AM
