Old 01-12-2007, 11:29 AM   #1
AnnabeltheCaravel
chalcedon's Avatar
1967 17' Caravel
Penetrating sealant.
Hello!
Does anyone know of any type of extremely low viscosity penetrating sealant that i could use to seal some rivets after instalation?
Thank you?
Eric and Elizabeth.
Vancouver B.C.
Annabel the 67 Caravel.
chalcedon is offline   Reply With Quote
Old 01-12-2007, 11:46 AM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Are these rivets above the lower rubrail trim area (main body, not underbelly)? You don't have to seal underbelly rivets; it is necessary to have a certain amount of breathing down there. Olympics? It is usually advisable to put a dab of Sikaflex 221 on an Olympic as it is placed. The factory & RV techs use a much thinner product if they have to seal a skin lap after the fact -- it's called Acryl-R. There's some mention of it if you use the search function. I haven't used it so can't tell you anything firsthand -- or where to get it. Google I'd say. It might have some ability to wick into a clean, dry joint. We need more experience reports if you'd mind posting back if you go this way. Thanks!
5 meter Langford Nahanni
Old 01-12-2007, 03:12 PM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Loctite has a wicking product much like their material they use to lock bolts. It sets up rigid so I do not know how it would do going down the road and flexing. There are some urethane glues such as Gorrilla glue that are moderately viscous and you may be able to push it abit under the heads. It swells as it sets up and is never real rigid so it might do the job.
Old 01-12-2007, 04:57 PM   #4
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
This:
Capt. (Captain) Tolley's Creeping Crack Cure Hairline Crack Sealer
However, it is best to seal the rivets during installation, with either Par Bond or Vulkem.
Uwe
www.area63productions.com
Old 01-12-2007, 05:41 PM   #5
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I used that stuff, it required several applications to seal the seam I was sealing.
I have had better luck with the Ruscoe crack sealer. It is thick, but flowable, and will flow into seam before setting up.
Old 01-12-2007, 05:46 PM   #6
uwe
418
uwe's Avatar
1974 29' Ambassador
Images: 41
That is correct, it says so in the instructions. It is of very low viscosity, flows into very small cracks.
Larger cracks must be treated several times.
Uwe
Old 01-12-2007, 05:55 PM   #7
Eric & Elizabeth -- Exactly what type and where are these rivets? What led to their installation like this? How many are there? That will help give you a better answer without so much of a scattergun approach. Thanks!
Old 01-12-2007, 05:57 PM   #8
Well Preserved
1993 21' Sovereign
I know. I just wasn't expecting to make 35 trips up and down the ladder to seal the seam.
Old 01-12-2007, 08:33 PM   #9
lewster's Avatar
Naples, FL , Hood River, OR
Airstream Company Store
Last time I checked, you could buy Acryl-R from the Airstream web site. Be sure that you order the applicator also and PRACTICE on some scraq before attempting to use it on your 'Stream. It takes a little getting used to but it is great stuff!
Old 01-12-2007, 08:43 PM   #10
Karma Lew! With that as motivation I easily found it (with applicator): Airstream :: Store
Old 01-12-2007, 11:39 PM   #11
AnnabeltheCaravel
chalcedon's Avatar
1967 17' Caravel
What happened is that we got ahead of ourselves and forgot to use parbond or vulkem on the bucket rivets while bucking them while replacing a couple of side panels, now i have a couple of small leaks here and there.
Thanks for the replies!!!
Eric..
Which Sealant Where? Jabba Leaks - Weatherstrips, Gaskets, Caulks & Sealants 16 02-05-2007 08:03 PM
Sealant Products - Exterior & Interior Cat Leaks - Weatherstrips, Gaskets, Caulks & Sealants 21 02-12-2003 10:00 PM
sealant Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 11-06-2002 08:41 AM
Vulkem sealant Stougard Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 07-01-2002 12:25 PM
Penetrating Epoxy Andy R Repairing/Replacing Floor &/or Frame 8 06-08-2002 06:12 AM
