Old 08-11-2003, 11:06 AM   #1
Jabba's Avatar
1955 30' Liner Commodore Vanderbilt
Wayne County , Michigan
ParBond Shrinkage?
I got a chance to re-seal some seams with ParBond recently. I must say, once I figured out it's flow characteristics, it is great to work with. My question is, is it normal for the bead to "shrink" or contract quite a bit after it has cured for a while? I realize it has a capillary action but didn't expect it would pull into the joint that well, or is basically cooking off the fluid portionof the sealant? Just want to double check my application (yes, making sure the joints are <1/8").
Thanks!
Jason & Veronica J.
S.E. Michigan
1955 Commodore Vanderbilt 30'
"Hawley"
TAC Member MI-6
2008 Chevy Silverado Ext. Z71 w3.73
Jabba is offline   Reply With Quote
Old 08-11-2003, 01:12 PM   #2
I have observed what you are talking about. I suspect the Parbond continues to flow into the seam or gap, which sometimes leaves a void when it cures. however, it may shrink some as well, I don't know.
Mark
Caulking and Sealants (silicone, parbond, vulkem & more) Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 266 07-01-2017 11:41 AM
Which Sealant Where? Jabba Leaks - Weatherstrips, Gaskets, Caulks & Sealants 16 02-05-2007 08:03 PM
finding/fixing leaks Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 10-16-2002 08:32 PM
caulking ALANSD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 07-10-2002 02:13 AM
