Old 12-15-2004, 11:49 PM   #15
wallybyam's Avatar
Parbond legality?
If Parbond is illegal, better lock me up! I have recently bought, at our local RV dealer, enough to stick Ted Kennedy to George Bush. I purchased and have used; silver, clear and grey. Can't beat the stuff! The squirrels, mice, birds, ants and spiders are as plentiful as ever, but the leaks stopped!
Crack is illegal, but if you wanted some you could probably find it. Illegal or not, if I wanted some Parbond, I would find it and use it.
Luck to you!
Bruce
wallybyam is offline   Reply With Quote
Old 12-16-2004, 01:32 AM   #16
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Well, I checked with airstreamdreams.com and they were out of parbond but their site states they recommend alcoa gutter seal for seams.
Since I already a had some of that I taped up the seam real good an applied it.
I'm giving a good couple of days to cure before I hose it. Its the vertical seam just under the front wrap windows. I hosed it before I started and could tell it was getting the inside edge of the floor wet.
-Tim
theVAP - Airstream Podcast
Old 12-16-2004, 06:14 AM   #17
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Last Sunday, Nickcrowhurst stopped by and helped me replace the right front banana wrap, that was damaged by a "road gator". After everything was riveted back together, Nick got out his "Acrylic R" and sealed everything up. Nice stuff, that applicator is the cat's meow!
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Univolt FACTS smily Electrical - Systems, Generators, Batteries & Solar 69 08-19-2005 12:47 AM
California Emissions spinolio Airstream Motorhome Forums 3 11-11-2002 10:49 AM
Trailer Friendly Camping California bkpine Our Community 31 08-19-2002 02:26 PM
Tear Drops !!!!....... canny_banjo_man Our Community 13 08-19-2002 01:49 PM
caulking ALANSD Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 07-10-2002 03:13 AM
