Old 03-14-2006, 09:24 PM   #1
1963 19' Globetrotter
Moline , Illinois
Parbond for leaking tail light gaskets?
Several days ago we had some really bad storms in our area. Large amount of rain and 107 MPH wind a mile from where my trailer is stored. A very tense night to say the least.
In checking my trailer I found the floor was wet under my bathroom vanity Nothing appears to have come in around the windows or vents so I looked at the tail lights and the gaskets are cracked so I suspect the water entered there. Are new gaskets available or do you make your own and if so out of what? My other thought was to mask them and run a bead of Parbond on the gasket edge. Whats the way to best solve this problem?
63air is offline   Reply With Quote
Old 03-14-2006, 09:48 PM   #2
Boise , Idaho
Images: 21
I doubt it came in from the tail lights but it could. I would look harder at the holding tank vent and windows.
Randy
www.bestconverter.com
rvtirepressure.com
Old 03-15-2006, 03:09 AM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Gasket material is available at places like Napa, I would either use Cork or a piece of EPDM rubber, like you get off a building roof. Just cut your own using the old one for a pattern.
Aaron
WBCCI #XXXX AIR #2495
Old 03-15-2006, 07:59 AM   #4
Moderator Emeritus
85MH325's Avatar
Tipton , Iowa
Images: 37
I'd be more suspect of the holding tank vent gasket as well, or perhaps the bath fan vent gasket. You don't mention what the arrangement of your bath is, but it's entirely possible in some trailers that with that kind of wind speed it could have just blown rain in under the window gaskets too.
Roger
AIR 2053 Current: 2006 Bigfoot 25RQ
Airstreamer Emeritus: 1953 Flying Cloud, 1957 Overlander, 1961 Bambi, 1970 Safari Special, 1978 Argosy Minuet, 1985 325 Moho, 1994 Limited 34' Two-door, 1994 B190 "B-Van"
Old 03-15-2006, 09:14 AM   #5
Moline , Illinois
Thanks for suggestions where to look. I've got a '63 GT so no bath fan I'll start with the holding tank vent. I suppose the wind speed also could have forced it in the rear window but I have new seals on everything. If that was the case shouldn't I have seen something on the walls or counter under the window? It's a nice day and I'm off so so I'm off to find this leak.
Old 03-20-2006, 12:35 PM   #6
Moline , Illinois
Found the leak. It was the right tail light. Water was coming in through a crack in the sealant on the light assembly and following the wire in through the grommet. All fixed now - I hope
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
'66 tail light bulbs Derk Lights - Interior & Exterior 8 01-28-2006 09:43 AM
left back-up tail light Margo Schock Electrical - Systems, Generators, Batteries & Solar 6 12-16-2002 12:52 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
Bargman #99 wedding cake Tail light needed cindy Lights - Interior & Exterior 8 10-16-2002 08:52 AM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
