Old 09-12-2005, 01:50 PM   #1
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Thumbs up Old dried out gaskets
Looking for a source for replacement gaskets for a '75 Trade Wind? Originals are quite degraded and leak purdee good in a driving rain....
They look to be form fit, has anyone replced with bulk material?
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 09-12-2005, 02:11 PM   #2
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
I purchased mine by the foot from oasisrv.com.
It's quite the project replacing them. You really need to remove the windows and clean the old gasket material off really well. I used a dremal with a sanding wheel.
Also make sure you use the 3M super gasket adhesive to put on the new gaskets. Anything else won't hold up as well. I was able to find some at a local auto paint store.
-Tim
theVAP - Airstream Podcast
Old 09-12-2005, 03:42 PM   #3
Check out the Vintage Thunder blog as well. Rich Luhr, (rluhr), had a step-by-step process on there for replacing the gasket material.
Anon is offline   Reply With Quote
Old 09-12-2005, 06:30 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
InlandRV's prices seem somewhat Californish but I did my gasket replacement through them. I also have migrated to checking out Oasis RV first. Ditto on the 3M product. This is definitely a winter project and you must take the windows off to do it. After removing the gaskets with a cobbler's knife aided by some mineral spirits as that job got more complete, I used a circular wire brush from the hardware store in my electric hand drill. I don't think you want or need a real sharp utility knife -- do damage to yourself and knick up the frame more than you want. I think my job benefitted from having the slight steel wire texture added to the window frame metal.
5 meter Langford Nahanni
Old 09-12-2005, 07:11 PM   #5
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Good info, I'll have it stored inside after Xmas, best to di it then.
www.balrgn.com
Old 09-12-2005, 07:54 PM   #6
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Are you guys using steel wire wheels and knifes on your aluminum window parts? That's a no-no on aircraft parts because there's no way to keep small peices of the wheel from embedding in the aluminum, which later leads to dissimilar metal corrosion and eventual failure of the part.
Yep, the voice of gloom. That's me.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 09-13-2005, 03:41 AM   #7
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Lamar
Your absolutely right, I never use iron brushes, Stainless or Brass..........
www.balrgn.com
Old 09-13-2005, 03:47 AM   #8
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Lamar
I use brass wire wheels or in extreme cases stainless steel. As far as scrapers are concerned Stainless or wood....
Aaron
WBCCI #XXXX AIR #2495
Old 09-23-2005, 10:44 AM   #9
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Cool Got gasket
Found the gasket replacements! Ordered 75'. Received then in 3 days! Way to GO Oasis R!!!
Picked up some 3M Super Weather strip. Thinking of trying the solvent that I stripped off the clear with once the bulk of the old material is off.
www.balrgn.com
Old 10-01-2005, 03:20 PM   #10
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Cool On with the new gaskets
Finally had a chance to replace a couple window gaskets. Stripped off the old rubber, scraped as much as I could with a SS Scraper.
Used Por Srtip loosen up resdual adhesive and rubber. Worked great, very little to wire brush!
15 minutes for each of the smaller windows.
www.balrgn.com
Old 10-01-2005, 03:41 PM   #11
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Balrgn, Do you buy that by the foot? What is the cost?
Richard
Old 10-01-2005, 03:53 PM   #12
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Azflycaster,
I buy mine by the foot from my closest AS dealer and pay around $.70 lf for the window gaskets. FWIW they are www.outofdoorsmart.com in Colfax, NC and they will ship if you need them to. They are vintage friendly and do not mind special ordering parts if needed. IIRC they have been an AS dealer for close to 40 years.
Aaron
Old 10-01-2005, 04:00 PM   #13
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Smile
Called my local dealer, they could not help, worse yet, did not return my call...
Got it from Oasis RV, .75 a foot. I ordered 75 feet, yes it is by the foot. Delivered in 3 days!
Oh yeah, Part ID was Gasket, Main DOor 69-73 Window Gasket
www.balrgn.com
Old 10-02-2005, 11:35 AM   #14
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
That was easier than I had expected!
ID:	15023   Click image for larger version
ID:	15025   Click image for larger version
www.balrgn.com
Polishing tips? Rog0525 Cleaning, Stripping & Polishing 10 04-30-2007 08:27 PM
Gaskets, vents, etc... Chuck Windows & Screens 3 10-27-2002 02:18 PM
roof stack gaskets bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-25-2002 05:29 PM
Taillight gaskets? davidz71 Lights - Interior & Exterior 0 09-10-2002 05:26 PM
dried adhesive removal, again Rog0525 Cleaning, Stripping & Polishing 8 08-18-2002 01:29 AM
