Old 10-10-2005, 05:39 PM   #29
Gasket removal.
Chemicals, of any kind, are not needed.
You can use most any type of wire wheel, that your comfortable with.
Brass, steel, stainless steel, all the same. Makes no difference to the aluminum.
After burnishing, you should wipe the aluminum off to make sure it's grease proof. Any traces of another metal then become nil.
I have used this method for 40 years. It's never caused a problem.
Old 10-10-2005, 05:41 PM   #30
Remember Burma Shave!
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Fort Myers , SW.Florida
Images: 35
Rivet Wire brush material ...
You can use either material, that's up to you!
The brass wires will not be as efficient and surely more expensive.
The steel wires will be more efficient and can be found in many more levels of stiffness.
Each will shed pieces of the wire when in use. The small pieces of steel will rust and contaminate whatever they rust on, when exposed to moisture.
Using steel on a waterborne yacht is a huge No-No because the particles get on the teak wood or paint and leave rust marks, particularily around salt water. In an aluminum yacht they can even cause electrolytic deterioration to the aluminum hull.
I don't think you will have any problems using the steel around your airstream, just clean up afterwards. I have never encountered problems using steel wire wheels around my Airstreams.
And, you can always go to stainless steel, if you just have to have numerous choices. As the Nike logo states "Just Do It!"
Balrgn's technique sounds like a good one! A welders brush is a great tool to have around.
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 10-31-2005, 01:10 PM   #31
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by balrgn
Posted a new page, if anyone is intersted in the disassembly / assembly...
I too have just posted a new page on replacing the window seals on my 1967 Overlander.
Tom
Polishing tips? Rog0525 Cleaning, Stripping & Polishing 10 04-30-2007 08:27 PM
Gaskets, vents, etc... Chuck Windows & Screens 3 10-27-2002 02:18 PM
roof stack gaskets bhsl8 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-25-2002 05:29 PM
Taillight gaskets? davidz71 Lights - Interior & Exterior 0 09-10-2002 05:26 PM
dried adhesive removal, again Rog0525 Cleaning, Stripping & Polishing 8 08-18-2002 01:29 AM
