Old 01-13-2016, 07:45 AM   #1
jmark64's Avatar
1971 31' Sovereign
Big Spring , Texas
Old Caulk Removal?
What's the best way and/or products to remove old caulk from outer skin roof?? In the process of polishing and need to get old caulk off.....THANKS! Also could use tips and products to reseal as needed.
jmark64 is offline   Reply With Quote
Old 01-13-2016, 08:01 AM   #2
grizbear's Avatar
2004 25' Safari
Crestview , Florida
Caulk removal
I used a very sharp 1/4" chisel went very slow took about one hr to go down each side of the seam along the top edge. Then used mineral sprits and rag to clean up. I used trempro 365 as replacement. Good camping Rand
grizbear is offline   Reply With Quote
Caulk caulk and more caulk amazingwoody Leaks - Weatherstrips, Gaskets, Caulks & Sealants 28 03-23-2015 10:16 AM
Old, old, old airconditioner removal bilby05 Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-17-2012 04:19 PM
To Caulk or not to Caulk? marchesi Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 07-24-2009 10:43 AM
