Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Leaks - Weatherstrips, Gaskets, Caulks & Sealants
Old 10-16-2005, 11:34 AM   #1
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Nuisance leak
I had a nuisance leak for the past few months where the penetration for the antenna is. Water develops on the inside of the handle and if it rains enough it drips. Well after 16 ounces of water the best this is to find the problem before it develops into an issue.
Follow this link to see what I found!
http://www.balrgn.com/Airstream/Leak/leak.htm
ID:	15241   Click image for larger version
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
Last edited by Pahaska; 10-16-2005 at 04:44 PM. Reason: Please use standard font size
balrgn is offline   Reply With Quote
Old 10-16-2005, 02:52 PM   #2
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
Somewhere , Over the Rainbow
This was also found to be the source of the phantom leak on the Airstream Life project trailer. I wonder if it is just the coaches that are painted that seem to have this problem, or if all Airstreams suffer dissimilar metal corrosion like you found.
(No Longer at Inland RV)
Old 10-16-2005, 03:43 PM   #3
balrgn's Avatar
Images: 74
Found this on my 75 TradeWind, Not painted. I was kinda surprised it corroded that way. Maybe the shaft that holds the worm gear that produced a charge that fueled it....
Member of VAC
www.balrgn.com
Old 10-16-2005, 03:58 PM   #4
Well-Preserved
Did you have an antenna...
that had the signal amplifier in it? DC voltage going through two different metals will cause that. I saw this on an episode of Mythbusters, one of the guys used a battery charger to eat away the steel bars of a prison cell.
Water leak panoramic windows Andy Fay Windows & Screens 16 01-05-2007 08:33 AM
Water leak James Schmidt 1993 Excella 1000 11 02-02-2004 07:54 AM
'99 25' Safari water leak driving me crazy Raptorrider2001 1999 Safari 4 12-06-2002 06:34 PM
Rainwater leak James Schmidt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-11-2002 06:28 AM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
