Old 08-16-2016, 02:21 PM   #1
1971 18' Caravel
1970 27' Overlander
Hawthorne , Florida
Other Urethane caulks (NP1, OSI)
My handyman advocates NP1 (Master Seal, formerly Sonolastic) for flexible, long enduring joint sealing. The label says it's a high performance polyurethane sealant. It this an ok substitute for Vulkem 116?
Lowes carries OSI Pro-Series 10.2 Oz. Polyurethane Door, Window, Siding White Sealant, which also looks like it might work on aluminum and is rated for 50 years. Is it any good?
sandgrubber is offline   Reply With Quote
Old 08-16-2016, 04:07 PM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I have used NP1 extensively in commercial construction. I also used it on the exterior of my home. It's a really good caulk for its intended uses. Though, I've found the colors fade when exposed to sunlight? It would probably be ok on your trailer for large joints (around windows, doors, awning rail, etc). But, I would not use it on my trailer.
Caulk caulk and more caulk amazingwoody Leaks - Weatherstrips, Gaskets, Caulks & Sealants 28 03-23-2015 10:16 AM
To Caulk or not to Caulk? marchesi Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 07-24-2009 10:43 AM
caulk removal Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 10-17-2002 08:56 AM
