Old 05-04-2009, 04:43 AM   #1
JackP's Avatar
1972 27' Overlander
New Haven , Connecticut
Newbie with a roof leak
I just purchased a 72 overlander and have a roof leak where the antenna crank enters the roof of the trailer. I want to remove the antenna and patch the hole but I have a few questions.
Where do I get the sheet aluminum to make the patch and what thickness do I get?
From what I read here, Vulkem seems to be the sealant of choice. Can I purchase that locally and exactly which Vulkem sealant do I get?
Lastly when it comes to rivets...which rivets do I use for this repair? It seems that with some rivets the post (the nail like thing) in the middle stays inside the installed rivet and others don't. (Am i correct about this?)
I know these are very basic questions and I do appreciated any help.
Jack
JackP is offline   Reply With Quote
Old 05-04-2009, 05:56 AM   #2
toastie's Avatar
1955 22' Safari
Great Lake State , .
Jack
Try
Airparts Inc. Homepage
Vintage Trailer Supply - Vintage travel trailer parts and supplies!
Toastie
toastie is offline   Reply With Quote
Old 05-06-2009, 10:20 AM   #3
blickcd's Avatar
Milford , Ohio
Just my two cents here but unless you plan to install stuff on the roof and the lowered antenna will be in the way, I would suggest leaving it in place and just re-sealing around the base flange with some Vulkem. Even if you don't plan to use the antenna, if you sell your trailer in the future a prospective buyer will most likely want to.
That said, if you are set on removing the antenna, after you do so, I suggest coiling up as much of the cable which was on the roof and stuffing it in the gap between the roof and ceiling skins. That way it is there should a future owner want to reinstall the antenna.
The patch on the roof could be as simple as a small piece of aluminum flashing that is "glued" into place with Vulklem. You could pop some olympic rivets into some of the original screw holes for the antenna base, but really the Vulkem alone should do the job.
For the interior hole, I would personally cut another piece of flashing as round as possible, and "glue" in into place with just a few dabs so it won't ooze out and be visible. After all the interior one won't need to be water tight. Once it is bonded in place you could paint that interior patch to match the ceiling as close to the original as possible, or maybe install another light fixture in the same location to cover the hole.
Christopher
blickcd is offline   Reply With Quote
Leak at roof vent Nightwind15 Roof Vents, Skylights & Fans 3 12-27-2008 09:32 AM
Roof repair advice - hole in roof 1956 vintage casaalumina Roof 5 10-05-2008 10:24 PM
Roof vents leak... SLVRSRFR Roof Vents, Skylights & Fans 11 10-01-2007 05:12 PM
Cleaning debris from roof? White roof? maxandgeorgia Cleaning, Stripping & Polishing 1 06-05-2004 09:59 PM
Another newbie question... fan on roof??? flamingo-kid1 Roof Vents, Skylights & Fans 5 07-27-2003 09:12 PM
