Old 07-01-2016, 09:07 PM   #1
2014 25' Flying Cloud
Apple Valley , California
New Owners & our Refrig. Why Isn't it cold?
Our new 2014 flying cloud's refrig says 53 degrees on the outside gadget. I'm assuming that's the temp inside? It's been on for more than 24 hours and it doesn't get lower than 53. I'm suppose to see about 36 degrees right? I'm afraid to put in food, but would the cold food help to keep the refrig at a lower temp? is this normal or is something wrong with my refrigerator? any advice is welcomed. We leave for Yellowstone in the morning! Our first trip in our Airsteam
Ju-Lina 2014 is offline   Reply With Quote
Old 07-01-2016, 09:11 PM   #2
Some Guy
djarrett's Avatar
2018 28' Tommy Bahama
Nashville , Tennessee
We recently experienced this. We simply turned the fridge off for a few minutes. When I turned it back on, I switched it from 110 to gas and let it run for 24 hours, assisted by a few cooler ice packs. It came on down and then I switched it back to 110 and turned the gas off. This may not help in your case, but ... it's worth a try.
The Jarretts
Nashville, Tennessee
2018 27' Tommy Bahama
2015 F250 TV-Petrol
WBCCI # 22342
djarrett is offline   Reply With Quote
Old 07-01-2016, 09:14 PM   #3
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Are you running it on LP? There are two things to check. 1)that it is running- make sure you have the dot by LP and 2) your "thermostat" plastic white clip thing has to have the wire inside the clip and be attached to the end metal grill. There is an arrow on the right side of the fridge inside. Like djarrett said, make sure to cycle the power. I have found with the new fridge that it gets fussy switching between electric and gas and it is anything but automatic at times.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
New refrig-Not real cold Rich of SCal Refrigerators 18 06-03-2012 08:31 PM
Why isn't a response visible in New Posts? DougZ Forum Admin, News and Member Account Info 11 06-26-2011 12:02 PM
Uh OHHH the fridge isn't getting cold arcamedies Refrigerators 9 06-29-2010 07:35 AM
Why isn't gaucho up against the wall? outerbanksdeb Interior Restoration Forum 3 02-05-2005 07:46 PM
Why isn't anybody chatting with us? Ken J Off Topic Forum 25 12-09-2004 08:44 PM
