Old 02-02-2015, 06:06 PM   #1
SilverEagle6's Avatar
2013 25' Flying Cloud
2008 30' Classic
On The Road To Wherever We End Up , Traveling the USA
Need help with a leak
We have a rain leak that comes in above four control panels on the curbside of our 2013 Flying Cloud 25. The water leaks into the trailer behind the water pump and tank gauge panel and then straight down to a non GFI plug, then solar monitor then inverter on/off switch. Been suspecting the outside stove vent and/or the exterior moonlight. Just prior to a nine hour rain shower, we covered that area and no leak. Decided to make an appointment at a dealer to inspect the room area. Note: am out of warranty. We are now in a campground so I removed the covered are over the vent and light and ran water for about an hour....no leak.
Before I go to the dealer, does anyone have any idea on where the leak maybe coming from?....maybe experienced the same thing? Appt is tomorrow AM.
Thanks, John
Jeanne and John, and always with us...Jake
2008 30' Classic Ltd Rear twin, 2014 Ford Super Duty
WBCCI 3100, unit 12, TAC USA-1, Escapees 129379
https://instagram.com/silvereagle3100/
SilverEagle6 is offline   Reply With Quote
Old 02-03-2015, 05:14 AM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Your description makes it sound that it's important to get this leak repaired. That's a lot of electrical / electronic gear that may be subject to moisture. I bet your dealer will get the leak stopped.
I do know rain water leaks can be a challenge to find. Maybe someone who has a similar trailer with a similar leak will chime in. I remember reading Airstream exterior marker lights can be a leak problem, as well as window frames and any other exterior skin penetration. Even the seam rivets can loosen up and begin to leak.
100 pound lap dog? That will keep you warm on a cold evening!
David
dbj216 is online now   Reply With Quote
Leak then no leak. gandttimes Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 10-04-2013 01:34 PM
Water leak - Need help. Doug C Fresh Water Systems 4 03-22-2013 09:15 AM
Need help with leak! Fam-Bambi Water Heaters, Filters & Pumps 1 03-29-2012 05:09 PM
Leak: Fired Up Hot Water, Now There's A Leak SSChanger Fresh Water Systems 4 07-15-2009 08:46 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
