Old 12-18-2015, 07:38 PM   #15
silverbacksurfer's Avatar
2005 25' International CCD
Glendale , California
eternabond on fantastic fans
I have photos of my trailer with the new eternabond on the fans. you can get it a granger. http://www.airforums.com/forums/f455...cor-96561.html
silverbacksurfer is offline   Reply With Quote
Old 12-19-2015, 06:08 PM   #16
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I used to have a 1994 AS LY motorhome (diesel pusher) that suffered with roof leaks. I used Eternabond to seal the roof seams (and it did a good job of stopping the leaks). However, I'm not so sure that just using a hair dryer would allow the tape to be released. It chemically welds the tape to the roof. On the motorhome, the roof was fiberglass - the same type as is used on sailboat decks - the walls were fiberglass laminate and the quarter round where the roof and the walls met was aluminum. The Eternabond welded itself to the aluminum and could never be pried up.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 12-20-2015, 06:10 AM   #17
removal of eternabond
here is a link https://www.eternabond.com/articles.asp?id=165
Old 12-20-2015, 06:16 AM   #18
I did not say it would be easy what is about fixing a leak on a trailer here is u tube video .
Old 12-20-2015, 07:21 AM   #19
Pygmypoacher's Avatar
Black Diamond , Washington
Originally Posted by silverbacksurfer View Post
look at this thread http://www.airforums.com/forums/f455...cor-96561.html I have the eternabond for 3 years now you cant beat it when you need to replace it who knows when , just use a blow dryer on it and pull it up watch the video.
Do you see any drawbacks to using eterabond on the ZipDee awning attachment to the AS? They have a alumibond product as well - any experience with this? Thanks for your time.
Pygmypoacher is offline   Reply With Quote
Old 12-20-2015, 07:37 AM   #20
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Can you describe more of what you mean? If you are meaning the upper and lower mounting brackets, I would suggest removing the brackets one at a time, clean the back surface of the bracket and the skin of the trailer, apply a layer of ParBond http://www.vintagetrailersupply.com/...-p/VTS-256.htm then reattach the bracket to the trailer. I can't imagine a good way of using the Alumibond to seal those brackets. However, I could see using the narrower Alumibond tape to seal the upper edge of the awning attachment strip on the trailer. And, I used the Alumibond to seal the seams on top of our Avion, and around the air and plumbing vents. http://www.airforums.com/photos/brow...c=3530&userid=
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 12-20-2015, 05:09 PM   #21
i don't think i would use it on the zipdee drip rail if that is what your talking about I think I would clean out old and replace with original caulking
Old 12-27-2015, 06:18 PM   #22
TexasVine's Avatar
2011 22' Sport
Fredericksburg , Texas
Originally Posted by PaulnGina View Post
Looking closely at where you pointed to the hairline crack, I would definitely us the 4" Eternabond AlumiBond tape. Cut a strip for each side of that vent, make each strip about 4" longer than the vent edge that contacts the roof. Lay it so it covers the seam that contacts the roof, and make it cover the vertical edge of the vent as well. You can trim the ends of each strip to allow you wrap the tape around each corner of the vertical edges of the vent. I found that a pair of tin snips trimmed the Eternabond tape nicely.
PaulnGina
1987 Avion 34W
Blessed and highly favored
I have noticed that a few have suggested the aluminum tape (Eternabond). On their web page they also offer a non aluminum tape as well. Being that the roof area on my 2011 is some sort of plastic material will the aluminum tape still be the better choice?
TexasVine is offline   Reply With Quote
Old 06-28-2016, 07:44 PM   #23
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
Here is a pic of mine with eternabond tape. It's the bomb and I don't know why more people don't use it.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Fixing an AC water leak (during rain- not running) Wingeezer General Repair Forum 2 02-26-2013 06:55 AM
Fixing leaks on roof Rickman4 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 06-08-2011 05:23 PM
Advise please - LA area to San Jose CA Bambi_Bandit On The Road... 20 12-19-2008 08:13 AM
window broke, need advise on how to fix infinite LUX Our Community 4 08-03-2003 08:55 PM
Need some advise maybe a Rally of a different kind.. JodynJeep Our Community 5 02-01-2003 11:11 AM
