Old 06-12-2015, 06:10 AM   #1
Mystery leaks.
We have noticed a couple leaks in our 1981 international. 1 leaks happens when. It rains heavy on the front side window appears to be leaking from a seam up top then running down the inside window frame the second leak happens when a/c is turned off after running water is leaking down in to window and dripping down inside camper into bed is there some type of silver sealant we can use on roof seams. Thanks
msasse is offline   Reply With Quote
Old 06-12-2015, 07:27 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Silkaflex or Alcoa Gutterguard
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, and leaks again danesh Leaks - Weatherstrips, Gaskets, Caulks & Sealants 16 09-08-2007 08:32 PM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
12 VDC Mystery roessler Electrical - Systems, Generators, Batteries & Solar 3 08-01-2002 05:20 PM
