Old 07-02-2010, 04:44 PM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
mystery caulk
PO had a leak in the reefer vent.He removed the vent and put an oval patch on the hole with screws.He liberally painted the surfaces with silicone(which is coming off with elbow grease)He sealed around the oval seam with a white substance that appears to be some sort of caulk.It is very hard.What do I use to remove this?
bwaysteve is offline   Reply With Quote
Old 07-02-2010, 04:57 PM   #2
JSTOTT's Avatar
1965 26' Overlander
Chapin , South Carolina
Jackhammer if it is real hard
We had some caulk or glue on the outside and we scraped off the big stuff with a putty knife, used an adhesive remover and then went at it with the buffer to get rid of any minor scratch marks. It took a while but it cleaned up nice. Does the stuff soften up with a heat gun?
Good luck,
Russ
JSTOTT is offline   Reply With Quote
Old 07-02-2010, 07:40 PM   #3
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Good luck,
Russ
Haven't tried a heat gun yet.HF always has them on sale.Maybe a good purchase
To Caulk or not to Caulk? marchesi Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 07-24-2009 10:43 AM
What caulk goes here? Zstream Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 05-26-2008 03:40 PM
Caulk, what's some equivalent? lundfog Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 06-18-2006 07:57 AM
Caulk source? wyhjr Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 03-08-2003 04:14 PM
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
