Old 09-14-2010, 10:34 AM   #1
Bixby , Oklahoma
My 1977 Argosy has sprung a leak, Help!!
I have been doing some minor and repair to a 1977 Argosy that I purchased in the spring. Itís been through several rain storms since I have purchased it and found only one leak that we thought we had fixed at a local trailer repair place. However a big rainstorm just rolled in about an hour ago and I notice that the newly upgraded kitchen area had water on the counter. The old leak above the twin / dinette area had come back and a new line of slow leaking drops along the back of the bed on the left side of the trailer. The leaks seem to be coming from along the left side and coming in were the panels meet.
The trailer is not completely level right now due to the fact it is in my drive way.
I have not done any outside or body work so I don't think I caused this. All of my inside repairs have been to get the trailer ready for a 10 day trip that I will be taking with the wife and kids in 1 week.
Any suggestions / hints about common leak locations would be most appreciated.
Thanks in advance!
Truebrit is offline   Reply With Quote
Old 09-14-2010, 10:47 AM   #2
1978 Argosy 27
Lacey , Washington
Images: 8
Truebrit,
We have a '78 Argosy 27ft and it leaked when we got it. My wife and I rehabed the trailer. I chauked the whole trailer sevveral times and then had it painted. The Argosy does not leak now. jjustice
jjustice is offline   Reply With Quote
Old 09-14-2010, 10:54 AM   #3
nick6930's Avatar
1979 Argosy 27
1969 21' Globetrotter
1953 25' Cruiser
Front Royal , Virginia
I have a 79 28' Argosy stripped and polished. i had a hard time with leaks where the awning is connected to the trailer body. Just recualk the whole line and the screws up there. Also the windows tend to leak at the gasket area. I used silka caulking to take care of those issues.
Good Luck
nick6930 is offline   Reply With Quote
Old 09-14-2010, 10:58 AM   #4
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
Caulk, Caulk, and Caulk
Get a ladder and get on top of the trailer.
The old caulk may need to be removed...and
recaulked.
Find it and Caulk it.
kennethowens is offline   Reply With Quote
Old 09-14-2010, 12:09 PM   #5
Thanks in advance!
Check the sewer vent pipe cover gaskets, as they only last 2 to 3 years.
Old 09-14-2010, 03:50 PM   #6
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Could be the AC unit.
I have a '74 and it was the AC unit that was leaking. The water would run down the metal trim pieces where the interior panels meet on each side of the AC like the gutter on a house. The only time it leaked was when the wind was blowing along with the rain.
Old 09-14-2010, 08:05 PM   #7
Splitrock's Avatar
Sioux Falls , South Dakota
My 1976 had 11 leaks from the front of the walk door to the front rib. It still has one and I can't fix it. It's a designed leak. It's the release lever slot for the entry step. When it rains hard that hole floods the belly pan.
The last side leak I found, I had to remove the inside skin and sit on a milking stool while it rained to find. It was the middle side seam corner that looked fine from the outside.
Old 09-14-2010, 08:16 PM   #8
Thumbs down
When it comes to water leaks on an Airstream, looks can be very deceiving.
Old 09-15-2010, 01:21 PM   #9
Bixby , Oklahoma
Thanks for the input everyone. I did find some places that could use a quick caulk for our trip but also I found that Andy Rogozinski idea was spot on. The vent cover was cracked and missing chunks on the very top that you could not see unless right on top of it. I assume that the rain then flowed down towards the front of the trailer, as it was on a slight incline, leaking out wherever it could along the way.
Thanks for all your quick suggestions everyone, you are all a great source of information.
M
Water Pump Sprung Leak...Need advice FAST stonyfork Plumbing - Systems & Fixtures 10 06-14-2010 12:20 PM
1977 Airstream Argosy RV eBay Watch Airstreams on eBay 0 09-29-2009 10:40 PM
1977 land yacht 31 vs 1977 argosy minuet 20 joe77 General Interior Topics 3 06-30-2009 08:51 PM
Sprung a LEAK!!! Buttercup Plumbing - Systems & Fixtures 5 11-19-2005 11:32 AM
1977 Argosy slow-canoe Classic Motorhomes 3 02-27-2005 06:32 AM
