Old 12-21-2011, 07:07 PM   #1
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
More leaks in cold weather?
Has anyone noticed the AS leaks come and go with changes in the temp. I've been chasing a couple leaks the past few days and it seems as though I find more of them on colder days. I'm talking a change of 20-25 degrees or so. Am I nuts or is the metal expanding and contracting that much?
Flynavy is offline   Reply With Quote
Old 12-21-2011, 07:17 PM   #2
1981 31' Excella II
New Market , Alabama
Yes it expands and contracts that much. Aluminum has a relatively high coefficient of thermal expansion. Also polymers like vulkem will shrink and become hard when it is cold which also opens up gaps. Ask NASA about this one when they blew up a space shuttle when the O-rings got hard from the cold and would not seal.
I don't know if a totally leak proof Airstream is possible. This is why I think putting drains in the C-Channels is a good idea. I am also against completely covering the floor for the same reason. Floor coverings hide and concentrate water. If you know something is going to happen have a contingency.
Perry
Old 12-21-2011, 07:22 PM   #3
Flynavy's Avatar
1974 25' Tradewind
Col. Station , Ohio
Perry, how do you drain the channel?
Old 12-21-2011, 07:59 PM   #4
1981 31' Excella II
There is no way for water to get out of the C-channel unless you add a drain. There is a gap where the corners meet the straight wall sections and there is where it drains into the sub floor. There are other places for water to get out but all of them involve leaking into the sub floor. I would bridge the caps in the C-channel and put drains on each side. You would need 8 drains for all 4 corners. Something like this.
Limits of cold weather Boondocking handn Boondocking 17 03-25-2012 11:05 PM
Cold weather starting - Yamaha Generators tberkhouse Generators & Solar Power 4 03-19-2012 07:25 PM
Screen Door Weather Strip TBRich Leaks - Weatherstrips, Gaskets, Caulks & Sealants 0 12-17-2011 04:00 PM
Water tank-weep holes-mystery leak(s). Gator113 Fresh Water Systems 9 09-21-2011 02:39 PM
HELP! kitchen window leaks Jcashcollect Windows & Screens 4 06-23-2011 10:41 AM
