Old 09-22-2014, 08:23 AM   #1
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
Moisture inside interior window trim - normal?
I recently purchased a moisture meter to test my 2014 25' FC. Went crazy with it and the good news is there is no moisture in the subfloor or any areas that seem like an immediate concern.
I did, however, notice that there is moisture (or saturation really) under the interior trim of every window and around the door. I am going to assume this is normal and it's just the gasket that I'm hitting.
Can anyone confirm this?
Thank you.
SCOTTinNJ is offline   Reply With Quote
Old 09-28-2014, 04:47 AM   #2
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Silence = normal?
@living.somewhere.yonder | Instagram
Old 09-28-2014, 06:12 AM   #3
dznf0g's Avatar
Oswego , Illinois
Having trouble deciding exactly where "under the trim is. If you touch metal, the meter WILL go crazy. It can't distinguish between conductors. Like metal vs. water.
-Rich-
Old 09-28-2014, 07:57 AM   #4
1981 31' Excella II
New Market , Alabama
I think what you are experiencing is sweating. Anytime a metal object like a window frame is below the dew point inside the trailer, water will condense. Airstream stopped using double pane windows years ago, so windows can sweat as well. The water will end up under trim and other places you don't want it. A good idea is to use a dehumidifier or winterize and leave the trailer unheated when you are not using it. Warm air will hold more moisture than cold air. Also if you are living in a trailer when it is cold moisture will build up in the trailer from showers and breathing etc. So yes water condensing around window frames and trim is normal although not desirable.
Perry
How much condensation inside its normal? VeggieBullet Furnaces, Heaters, Fireplaces & Air Conditioning 4 06-28-2013 04:56 PM
Moisture inside wing window Okiestreamer Windows, Doors, Locks & Vents 9 02-05-2013 07:23 PM
Interior window trim 1969 calivw78 1965-1969 Sovereign 5 06-03-2011 12:31 PM
Interior window screen/trim jsapp Windows, Doors, Locks & Vents 11 04-17-2011 08:28 PM
need new inside window trim T&Cairstream Windows & Screens 4 02-19-2008 05:26 PM
