Old 09-26-2012, 05:59 PM   #1
1965 26' Overlander
Woodbine , Georgia
Mildew and musty odor
My wife and I are still looking for our 1st Airstream. She is concerned about mildew and musty odor building up in the humid south when the Airstream is not being used. What steps do y'all take to avoid this problem?
gamakai is offline   Reply With Quote
Old 09-26-2012, 06:15 PM   #2
cosmos's Avatar
1965 17' Caravel
Birmingham , Alabama
Images: 8
I think it's caused by leaks. Wet insulation. Seal up the panel joints and window gaskets. Park your trailer inside with the windows open. Repair any rotted wood. A fully stripped and resorted airstream smells great.
cosmos is offline   Reply With Quote
Old 09-26-2012, 06:19 PM   #3
1981 31' Excella II
New Market , Alabama
Keeping it covered and well ventilated is sound advice. They go down hill fast sitting outside without yearly sealing. A dehumidifier is not a bad idea either. Perry
Old 09-27-2012, 10:34 AM   #4
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
We use Damprid when parked (which isn't often as it turns out). That and ventilation as often as possible I suppose. No problems so far in Central Virginia part of the south.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 09-27-2012, 11:52 AM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I open my trailer up as much as possible. Pointless to run a dehumidifier when the trailer has any windows open. I only use it when the trailer is closed up. It is set on a controller that turns the dehumidifier on and off when the humidity goes over 45%. The dehumidifier does put out a lot heat. I do not have a roof vent. It was replaced by a PO with an AC unit
MICHAEL
Old 09-27-2012, 02:05 PM   #6
Airstreamer67's Avatar
Here in Louisiana where humidity levels are quite high, I use an electric dehumidifier to keep things fresh.
Before I used it, the walls were sticky and it became quite musty and unpleasant. With the dehumidifier removing a surprising amount of water, it always feels dry and even though it still gets hot, the trailer stays in much better shape.
I have my trailer under a roof. It it's not, the trailer should be inspected periodically for any leaks after rainfalls.
Airstreamer67 is offline   Reply With Quote
