Old 04-24-2011, 04:57 PM   #1
Vilonia , Arkansas
Main Door Gasket Replacement
Did I read that I should use the same D gasket for my door that I am going to use for my windows? The current gasket appears to be much larger than the gasket I am taking off of my windows currently.
Also I need a gasket for my screen door as well. Recommendations?
Chris
Dog Doc is offline   Reply With Quote
Old 04-24-2011, 05:42 PM   #2
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Hi Chris,
I used this from Out-of-Doors Mart on my Excella.
Vaughan
Old 04-24-2011, 06:25 PM   #3
Chris
No, the window "D" gasket is for 72 and older trailers.
You need the large triangular gasket for your door.
Old 04-24-2011, 06:29 PM   #4
Vilonia , Arkansas
Can I order that gasket from you in the morning? I am placing an order at your place in the morning for several other things. By the way, what time do you open up?
Chris
Old 04-24-2011, 07:24 PM   #5
Chris
7 am, California time.
A/C Replacement malopezmo Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-12-2011 02:34 PM
Replacement LED fixture under front cap Pat Conway Lights - Interior & Exterior 2 04-12-2011 01:22 PM
Replacement Gold Cone Light for '58 mello mike Lights - Interior & Exterior 7 03-17-2011 10:56 PM
'77 Argosy entry door replacement Camp Argosy Motorhomes 7 02-02-2011 07:37 AM
Pls HELP Replacement of Deadbolt in Handle of '90 Elf1 Doors & Locks 8 01-28-2011 08:16 PM
