Old 12-09-2010, 04:39 PM   #1
1965 22' Safari
Point , NW
LEXEL Sealant
Anyone ever used a product called Lexel for sealing leaks? It looks like clear silicon, however does not contain acetic acid, can be applied in temps from 0 F to 120 F, on wet surfaces, dries clear, and can be painted. Supposedly better adhesion, and elasticity than silicon. I found it mentioed on a aviation web site, indicating it is used to seal aircraft windshields between aluminum and plexiglass. Too cold and wet to use Vulkem or the others right now to stop a leak near the street side front window.
New to RV's, first one ever, it is a 65 Safari, owned it almost a month now. Thought I might try it, but do not want to mess up a nice trailer by doing something I might regret later. The manufacturer rep also informed me it is very difficult to remove once setup.
What are your thoughts and ideas.
Stan
Sburg58 is offline   Reply With Quote
Old 12-09-2010, 06:47 PM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Vulkem will work if it is not too cold. Best technique I have found is to use blue masking tape on either side of the joint to be sealed. Leaving a gap in the tape proportional to the size of the seam (in other words make the final bead just big enough to cover the crack without being ugly). Apply the Vulkem then smooth with your finger in one direction and then go back in the other direction. This evens out the seam and insures the vulkem is forced into the cracks that need sealing. Then as soon as you get it smooth with your finger, remove the tape and do not touch it again. Don't try tweak it, if you messed up let it dry and them do it again cause if you touch your smooth seam it will not match the rest of the area you smoothed, If you leave the tape on until the sealer starts to skim before removing it will leave little ridges but if you remove it immediately the edges will blend in and be smooth. Hope it works for you, my Trade Wind leaked like a sieve when I got it so I had plenty of opportunity to experiment and this technique worked the best for me.
Happy Holidays
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
sealant? kaydee General Interior Topics 3 01-23-2010 01:45 PM
Sealant Uses bsherman Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 12-09-2005 07:44 PM
Where to get sealant? blickcd Leaks - Weatherstrips, Gaskets, Caulks & Sealants 20 01-25-2005 03:57 AM
What sealant to use? Tinsel Loaf Roof Vents, Skylights & Fans 3 01-09-2005 07:29 PM
Sealant ? aviontt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 06-25-2004 07:30 PM
