Old 06-06-2009, 04:41 PM   #1
bullydogsmom's Avatar
1972 25' Tradewind
old mystic , Connecticut
Lets talk gaskets!
Is the same gasket material used on both the entry door and the screen door? I also used the black weatherstrip adhesive for the door, and man what a difference to work with, compared to the yellow, MUCH better sticking power.
Annette
bullydogsmom is offline   Reply With Quote
Old 06-06-2009, 04:46 PM   #2
Annette
Annette,
If you purchased the correct screen door gasket, it has it's own adhesive (sticky) backing.
Clean off the old screen door gasket and stick on the new stuff. Remember to do the bottom as well.
Never used that black adhesive on the screen door gasket.
Old 06-06-2009, 04:55 PM   #3
1972 25' Tradewind
Thanks Andy will do!
Annette
Old 06-30-2009, 05:38 AM   #4
1976 27' Overlander
Peoria , Illinois
What can I use to replace dried, cracked window gaskets on my 76 International? Is there a place I can order stripping? Can I go to Lowes and buy something equivalent? Is there a recommended adhesive? Thanks for you help! Steve
sfairbanks is offline   Reply With Quote
Old 06-30-2009, 06:15 AM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Rubber Seal – Specially Designed Shapes
Have used Permatex Super Weatherstrip Adhesive (black) over the years to re-attach un-damaged weatherstripping. Just follow the directions carefully.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 07-01-2009, 06:28 AM   #6
1976 27' Overlander
Peoria , Illinois
Thank you sir. Will check Permatex out. Steve
"I don't know where I'm goin', but I'm on my way!"
Old 07-12-2009, 01:40 PM   #7
rolla , Missouri
I had a leaky vista window. I managed to remove both the inner plexiglass window and outer glass window from the inside by first removing the aluminum retainer. I cleaned up the frame & outer window and am ready to reinstall. I need advise on what gasket material I need to use in the reinstallation. The stuff I removed was a heavy gray material. It measured 3/16" thick by 1/4" deep. I would like to reinstall only the outer glass window but will need some type of "backing" material to fill the space left by the plexiglass I removed. Is there a product out there that is recommended for this type of application?
busterbrown is offline   Reply With Quote
Lets talk HOCKEY streamer23 Off Topic Forum 77 06-14-2009 12:20 PM
Lets talk Hensley Arrow Hitches IrishRover2 Hitches, Couplers & Balls 20 03-02-2007 10:58 AM
Lets Go To The Dinner!! TIMETOGO Our Community 11 01-02-2007 04:13 PM
lets debate at eight! john hd Off Topic Forum 20 10-26-2004 05:45 PM
lets chat! john hd Off Topic Forum 2 08-17-2004 06:09 PM
