Old 07-03-2010, 08:44 AM   #1
Calgary , Alberta
Leaky Roof Window (2008 25' Safari)
Fellow Airstreamers,
I have a leaky roof window in my 2008 25' Safari,...noticed it after storing over winter. I noticed a little water accumulating on top of that clear film that separates the actual bubble window from the interior of the trailer. I pulled the trailer out for better access and obviously tilted the whole thing and the water dripped into the trailer. The mess wasn't a big deal as it wasn't a whole lot of water but the bigger concern is the leak itself. Im assuming its a worn seal and im hoping some silicone will fix it but has anyone experienced this before and how did you fix it??? Also,...how do you deal with maintenance on the roof of an Airstream?? Im assuming its not recommended to walk on the roof.
Thanks for the help everyone!!
M
Mihoff is offline   Reply With Quote
Old 07-14-2010, 10:45 PM   #2
2008 23' International CCD
Denver , Colorado
Hello Mihoff...
We just discovered the same leak on our '08 23' International. First I thought it was water forced in an otherwise "tight" area from miles of "driving" rain while driving. But it showed up just like yours: in between the two roof window panels. Then this weekend while lounging in the trailer I discovered where that water had run: out a rivet and around a window down the inside wall. Must be more water somewhere behind the wall too.
So, now we have the same issue. Does anyone know if the skylights are warranted? I'm seeing some small cracks (appear to be hairline but water might be getting through).
I also noticed when peering up on the roof that there had been generous amounts of while "official" caulking on various screws and edges of the sky light.
Are the hairline cracks the problem?
Can the sky light be replaced at home?
Or does it just need more caulk like all Airstream seams?
And as for being "Up On The Roof" with The Drifters, I read that you better keep your weight over the roof ribs and not between 'em. Like walking on rafters in your attic I guess.
Good luck. I'll keep watch on this and see what we hear; or hear what we hear.
Jim and Marsha
"Tow'd Hall"
AIR #35886
JimmyT is offline   Reply With Quote
Old 07-15-2010, 12:49 AM   #3
Originally Posted by JimmyT View Post
Hello Mihoff...
Unfortunately, hairline cracks in the "skylights" happen in time due to one or more screws that were tightened, "to tight".
The hairline cracks will indeed leak water.
Skylights should either be patched with a sealer, if you don't mind the looks, or replaced.
Old 07-15-2010, 12:58 AM   #4
Hello Mihoff...
Skylights can easily be replaced at "home" using a little caution, a good sealer such as Vulkem, and don't fasten the screws in to tight.
Old 07-15-2010, 06:58 AM   #5
1996 34' Classic
FordTruck's Avatar
1996 34' Excella
Locust Grove , Virginia
Images: 8
Apparently the Screw tightener person at the Mother Ship didn't know what he/she was doing because this problem seems to be systemic.
We took ours back to the Mother Ship to have the skylight replaced along with 6 pages of other items under warranty.
FordTruck
2016 GMC 2500HD Denali (Betsy 4)
1996 34' Excella 1000 (Arvin3 as this is our 3rd AS)
2010 TREK 2.3
Fair is where they put ribbons on pigs.
FordTruck is offline   Reply With Quote
Old 07-23-2010, 11:36 PM   #6
Calgary , Alberta
What kind of sealer can I use to coat the whole thing with?? I was thinking to heat the window up as its lexan anyway and once its toasty throw down a layer of clear resin with a paintbrush,...should go on rough but dry smooth,...i think? I dont really want to seal the hairlines with silicon,...will just wear off and get dirty quick. Any suggestions?
Thanks again!!
Old 07-24-2010, 01:12 AM   #7
Thanks again!!
Replace the cover with an after market.
Walking on the roof properly, causes zero problems.
New 2008 AIRSTREAM 25' SS SAFARI SE SPECIAL EDITION eBay Watch Airstreams on eBay 0 05-21-2009 10:40 AM
Brand New 2008 Airstream 25' Safari Sport eBay Watch Airstreams on eBay 0 04-23-2009 09:10 AM
New 2008 AIRSTREAM 25' SS SAFARI SE SPECIAL EDITION eBay Watch Airstreams on eBay 0 04-17-2009 02:30 PM
Brand New 2008 Airstream 25' Safari Sport eBay Watch Airstreams on eBay 0 04-06-2009 05:00 PM
2008 Safari SE 25' AB Model Colonial Airstream Commercial Listings 3 08-27-2007 11:47 AM
