Old 09-01-2003, 04:52 PM   #1
srgntpepper's Avatar
Leaky Outer Skin 63 Safari
Well Folks by using the Dye test method I have my leak narrowed down to one seam above the front window. My Question is what is the prefered method for re sealing. Should I remove all the rivets in the seam re apply Vulcum and re-rivet, or remove one old rivet and replace with a new one (with a dab of Vulcum of course!!!!) AKA one rivet at a time??????? Thanks alot for any input
Don
srgntpepper is offline   Reply With Quote
Old 09-10-2003, 07:43 PM   #2
well i removed enough of the old rivets on one of the seam to open it up a little and remove the old cloth tape sealer, cleaned with solvent, apllyed new vulcum with syringe and re riveted and no Leaks!!!!!! this process worked really well and I am gonna try it on the other leak next week.
Outer Skin Leak 63 Safari srgntpepper Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-23-2003 03:20 AM
63 Safari Dump Valve Questions srgntpepper Waste Systems, Tanks & Totes 1 09-10-2003 07:40 PM
Leaking Front Window '63 Safari srgntpepper Windows & Screens 1 08-16-2003 05:25 PM
Floor Replacement in 63 Safari srgntpepper Repairing/Replacing Floor &/or Frame 2 08-07-2003 07:20 PM
is glass for '63 Safari anything special ? oldvws Windows & Screens 3 11-25-2002 08:12 AM
