Old 03-08-2006, 08:38 PM   #1
_
leaky marker lights.......how to fix 'em?
hi folks
most; maybe all of us have had water get inside the marker lights, or clearance lights......on out silver palaces.....
i've had this problem for 25 years and not seen a great solution......
my current trailer has the teardrop lights but it seems most of the marker light varieties get water in them....on airstreams.
i've not seen this on newer, maintained sobs.......
but airstream from the 70s to new......sure have it....
the look of water behind the light covers is annoying but the real issue is that the fixture is negatively afffected by the water. as a result the bulbs burn out much quicker than they should....the fixture corrodes and doesn't conduct well, the light are dim, the current draw is funky...and so on.....
so carrying extra bulbs is par and having them burn out while traveling can be a safety issue....
i want to be seen! i want dry lights! i want a fix!
one solution would be to remove and replace all the lights with a variety that do not leak.....but will not look original......
another solution would be replace the light fixture inside with leds...that should last longer.....even with water inside......
i have even seen folks use silicone to seal the lens inside the base....not me!
lewster has offered another potentially great solution here.........
http://www.airforums.com/forum...y-16147-8.html
by adding a rubber o ring under the machine screw that attaches the lens covers.....
skip to page 6/ post 87 of the thread for info........
of course the factory screws all rust from day one......so many of us have replaced these factory screws with stainless steel.....
i suspect the white base gasket leaks water around the edge but who knows where it comes from???
regardless there is water inside and i don't like it!
so if you've had this problem or solved it......
tell us how...... and pictures are extra nice....
so how do you solve this issue?
cheers
2air'
Old 03-08-2006, 08:53 PM   #2
jordandvm's Avatar
2017 28' International
Western , Oregon
Images: 58
2Air,
I must say that I haven't seen this problem yet with my 05 28' CCD........but....... also....... I haven't checked that close on my rig until the 2005 QC posts on these forums. I will now check to see if this is a problem with mine! If it is indeed a problem......IMHO it should be a warranty issue to be corrected by my dealer thru AS.....right?
Jim & Cheryl
2017 28' Signature CCD
2017 GMC Denali HD Crew Cab 4x4
Blue Ox Sway Pro Hitch
WBCCI #3538
jordandvm is offline   Reply With Quote
Old 03-08-2006, 09:24 PM   #3
Round on both ends
SafeHarbor's Avatar
1979 31' Excella 500
1975 28' Argosy 28
Rutledge , Georgia
Well, 2air,
You just got me to go out with the flashlight around 11:30 PM and inspect all my running lights. Since Spring in the southeast is RAIN, I expected to find some, but not a one of them show any signs of water having gotten in. This is a '79 Excella, and it has the running lights under the beltline. I also replaced a bunch of them in Ft. Desoto last year when my TV's headlight switch failed and blew a fuse in the trailer. Tomorrow, I'll hook the TV up and see how many of them have survived the winter.
Thank you.
Lamar
1975 Argosy 28 "Argosy"
1979 Excella 500 31 "Betsy"
1992 Lincoln Mk 7 LSC
2003 Dodge 2500 Cummins "TowHog"
"Lucy Loosehair" the cat - Airstream mascot
Klaatu barada nikto
SafeHarbor is offline   Reply With Quote
Old 03-08-2006, 09:26 PM   #4
_
hi jordandvm and safeharbor......
here's to hoping you don't have to deal with this.....on your 05.
some folks report water after washing....and are told not to spray the lights...duh.
mine has always been while towing in the rain......and having lived in seattle in a past life....that meant all the time.
i had my 05 at the factory in august and it rained for 2 days during the trip, and they all but one had water inside.....so while fixing other things i aasked them to deal with this.....
they did remove and clean/dry the covers and replace them....and assured my they would stay dry....until they got wet again.....and that i would need to "dry them out occasionally" if i really wanted them free of water....
this is one of those issues that's been around so long, it's sort of like finding metal shaving on the floor, screwing inside the cabinets or peeling clearcoat......
these things have sort of become "features" of owning an airstream....
i think it's more of a problem with the teardrops than the oblong markers...
and safeharbor......the clue that water is getting inside is any corrosion on the bulb base/or fixture...
when i picked up the new trailer last april......two of the yellow side markers blew even before leaving the parking lot.....with the first connection to t.v. power. it had rained during the trip from factory to dealership.....
cheers
2air'
Old 03-08-2006, 11:28 PM   #5
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Better move to AZ. I heard it hasn't rained there for 140 days. Our sealed led lights on our trailers at work still get water in them and they are supposedly sealed tight !
Into every Airstream owners marker lights a little water will leak
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 03-09-2006, 07:27 AM   #6
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
It almost rained yesterday. This weekend is looking good for a shower.
Richard
Old 03-09-2006, 08:28 AM   #7
cameront120's Avatar
1972 25' Tradewind
Just a thought that you might try. I used to do this when I owned a sailboat, with some success. I would give each screw a few wraps of that white plumbing tape when refastening my boats running lights' lens covers. I used to get leaks, even with new gaskets and figured the water was coming through the screws. Once I wrapped them with the plumbing tape and re-set them, I didn't have any more leaks. Also, don't set the screws really tight as this may be compressing the gasket in an irregular way and causing failure. I found that tightening snuggly but not tightly worked well. I hope this helps!
Cheers!
North Vancouver, BC
Old 03-09-2006, 09:14 PM   #8
_
hi cameront120......
thanks for posting about the teflon tape applied to the screw threads.....
i'm gonna try a few this way and a few with lewsters o rings.....
i agree over tightening may squash the gasket...i just don't know when to stop......
maybe inland andy has got a cure or other wisdom for wet marker lights?
cheers
2air'
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
marker lights dont work wb13798 Mechanics Corner - Engines, Transmission & More... 6 11-09-2002 11:40 AM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
marker lights bhsl8 Lights - Interior & Exterior 6 09-12-2002 06:01 AM
Rainwater leak James Schmidt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 09-11-2002 06:28 AM
