Old 03-31-2009, 05:13 PM   #15
VIKING's Avatar
Boulder Creek , California
Thanks Andy. I was hoping you would get back to us.
I have the same issues stated above regarding the stringers but not as bad. I was shocked at first that the stringers were not attached to anything at each end. At least there were no rivet misses in mine.
Rich
VIKING is offline   Reply With Quote
Old 03-31-2009, 05:23 PM   #16
Rich
Airstream, "did not" attach the horizontal stringers to anything from day one, until recently.
Another name for them was called "stiffners." That kept the oil can buckles off the flat metal.
When gutting an older trailer for a major overhaul, it would make the shell stronger, if the stringers were indeed attached to the main bows.
Old 04-01-2009, 07:13 PM   #17
1973 31' Sovereign
Amherst , New York
Good point, and it does not seem overly difficult to do with the interior gutted.
expat5 is offline   Reply With Quote
Old 08-22-2009, 10:09 AM   #18
san luis obispo , California
Has anybody used the huck rivets, which are used on Peterbuilt trucks
zues is offline   Reply With Quote
Old 08-23-2009, 08:58 AM   #19
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I'm very familiar with Huck bolts but not sure what type are used on truck bodies. The ones I have used on aircraft would be way overkill strength wise for an Airstream. If you could you post a picture of the back side I could tell what type they are.
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks maria 1959-69 Tradewind 5 11-09-2005 07:27 AM
Leaks Bob Ward Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 12-10-2003 06:23 PM
Factory rivet vs. repair rivet yukionna Ribs, Skins & Rivets 32 09-08-2003 04:41 AM
Leaks RyeDuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 07-02-2002 09:10 AM
