Old 04-11-2016, 11:19 AM   #15
Trailer's Avatar
2015 25' FB Flying Cloud
2016 25' Flying Cloud
Palm Springs , California
pressure test
The company who did our pressure test used the "pump/blower from a "Jumpy House." they didn't remove any vents as the rig they developed fit over the top of the roof vent with the vent open. The unit had soft material that made a good seal but I don't know what pressure in psi it accomplished. What it did accomplish was show us several leaks at joints and seams and windows. After the joints were sealed it still showed "bubbles" at the rear window. Still working on those leaks caused by poor workmanship on the part of the dealer, not Airstream. This is on a 2015 25'Flying Cloud FB.
William
"You know what we have right now? We have right now!"
Trailer is offline   Reply With Quote
Old 04-11-2016, 11:36 AM   #16
prairieschooner's Avatar
1958 18' "Footer"
Idyllwild , California
I found and cured a few leaks by using Duct Tape. I simply taped the area around the vents until I found the problem areas.
One of the leaks was where the vent was lifted and sealed with the new Vulkem that failed...I repaired it with Sikaflex.
Good Luck!
Steve
1958 California Built 18' #18-4092
http://www.airforums.com/forums/f106...on-122678.html
prairieschooner is offline   Reply With Quote
See more. Do more. Live more...? Mike91208 Airstream Lifestyle 2 01-26-2012 06:56 AM
Leaks, Leaks and more leaks Jim in Pima Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 12-12-2007 11:23 AM
Leaks, leaks, leaks jeffnjen30 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 08-27-2007 11:03 PM
leaks leaks leaks Globie64 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 10 12-31-2005 05:49 PM
