Old 11-30-2006, 12:36 PM   #1
1982 34' Limited
Chatham , Ontario
Leaks in the decorative molding!
I searched and didn't find anyone with this problem. frank spent some of the rainy day inside the airstream, and now it appears that the decorative stripe (some AS have blue, ours is wood grain) halfway up the exterior is leaking at the rivets. Has anyone seen this before??? We have visions of lots of silicone remover, and Vulkem in a syringe again. Argh!!!
Sharon
frank n'shar is offline   Reply With Quote
Old 11-30-2006, 02:06 PM   #2
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I'm not sure Silicone is the right stuff to use....I think Airstream uses Silkiflex (sp?) in all areas except the wheel wells. I seem to recall a number of posts saying stay away from silicone.
Old 11-30-2006, 02:12 PM   #3
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
She's talking about removing silicone, not using it.
Sharon, could the moisture be from condensation? Or is the moisture in one specific location?
Dave
Fyrzowt is offline   Reply With Quote
Old 11-30-2006, 02:14 PM   #4
Aluminut
2004 25' Safari
. , Illinois
Gotcha...my bad.
Old 11-30-2006, 03:38 PM   #5
CanoeStream's Avatar
St. Cloud , Minnesota
Are you talking about leaking into rivet holes at the beltline trim strip? About the only way to see this would be to have the inner skin & all insulation out. Or else I'm not understanding at all. Could you provide more information please? Thank you
5 meter Langford Nahanni
Old 12-03-2006, 07:55 PM   #6
1982 34' Limited
Chatham , Ontario
Yes Bob, good questions! The skins are out, the smelly insulation is gone, and frank has watched the water come in through the rivets. Do we remove the plastic strip and reseal the rivets on the outside, or remove the already plentiful silicone on the top edge of where the body meets the molding and replace it with Vulkem?
Old 12-03-2006, 08:05 PM   #7
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
Yes remove the silicon, but to put a bead of vulkem on top is not the best idea, water can get in there from the bottom with road spray and condensation.
To fix it 100% you need to remove the belt molding drill out the rivets and replace with new rivets and vulkem.
Another quick fix that would work is to cover each leaking rivet with a dab of vulkum from the inside?
'77 Sovereign Intl 31' CB
Old 12-04-2006, 10:03 AM   #8
1982 34' Limited
Chatham , Ontario
I think the concern with sealing the rivets from the inside would be that the water can still get between the molding and the outside - we're worried about any amount of freeze/thaw expansion here in the Great White North!
Old 12-04-2006, 11:20 AM   #9
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
yes, but that risk would be true even if you never had a leak as of now.
If you clean out the mating surface of the molding with something like a credit card and wash it out good I think that may help water from being trapped.
The vulkem will stay plyable a long time, if it didn't work over time you can then remove and re-rivet it.
blue trim molding larry smith Clearcoat, Exterior Paint & Trim 83 12-07-2003 11:04 AM
finding/fixing leaks Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 10-16-2002 08:32 PM
Quarter Round Molding melprice Floor Finishes 7 09-11-2002 10:59 AM
Leaks RyeDuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 11 07-02-2002 09:10 AM
Finding water leaks FrankR Plumbing - Systems & Fixtures 0 06-27-2002 08:36 AM
