Old 01-01-2010, 04:50 PM   #1
TankerIP's Avatar
2002 22' International
Leaks fixed at Jackson Center
Almost two months ago we traveled to JC to get the rear flooring fixed and leaks sealed. ( http://www.airforums.com/forums/f42/...-oh-58049.html ) I just realized that I had not reported on all the leaks we found. Maybe some of you might be interested from the standpoint of checking your own trailer for similar problems.
I know I wish I had known a couple of years ago what I know now. I might have been able to prevent some of the damage. This is definitely one of those "forewarned be forearmed" situations.
1. Bumper area - The bumper allows the water to "pool" against the back of the trailer. This water can work its way under and behind the rubrail. Once it gets there the water can enter through the c-channel through any kind of holes that happens to be there: i.e., screw holes, rivet holes, etc. Our floor was completely rotted the full width of the floor in the rear. Unfortunately the leak and damage was "hidden" by the plastic covered carpet under the cabinet and wet bath closet. To find the leak you would have get your hand under the plastic carpet covering to feel the moisture.
Here are some other posts on the same problem
http://www.airforums.com/forums/f396...eak-56099.html
http://www.airforums.com/forums/f477...ign-23121.html
http://www.airforums.com/forums/f456...ybe-56674.html
2. Furnace vent - This vent has two parts: intake and exhaust. Both parts have to have their own seal. Mine only had one sealed when I first discovered it. http://www.airforums.com/forums/f456...ing-56342.html This area could have leaked in on the carpet/OSB subfloor for 7 years before I discovered it last month. Our shop technician resealed this area after taking thinks apart.
3. Refrigerator - Rain water, under the right circumstances can enter into the refrigerator compartment through the louvered compartment doors. There generally is lots of caulk around the edges in that compartment to keep the water from entering the trailer. In my cases the bottom louver door opening had a "dam" at the edge that prevented any water from being able to run out once it got in there. Our factory shop tech remounted the frig so that any collected water would flow out of the compartment.
4. Right rear tail light. I thought I had completely checked this before and so was embarrassed when Jon pointed it out to me. He caulked the tail lights very well. Lesson learned: Check your seams and caulks over and over --- and frequently.
5. Rear Awning foot - I didn't notice anything here, but it stands to reason that wherever there's a screw or hole in the skin, it could leak. Jon at JC said it had a small leak and recaulked this area.
6. Outside compartment door. This is a weird one. The compartment door has a wire rope to hold the door in the open position. This wire rope was fastened in a position where the rope would press on the rubber grommet around the door frame when the door was closed. Apparently, the rope interfered enough to allow a very small leak. Simply rescrewing the rope in a different positioned fixed it.
7. Rubrail in front. Twice we have driven through some rain storms and then noted moisture in front under the desk/cabinet by the bed. Our technician thought water could be entered through the rubrail or down a window (see next). He re-caulked the top of the rubrail.
8. "Eyebrow" seam over front window. He said the caulk link showed signs of cracking.
9. Roof vents. While there was no clear evidence of a leak from any vent. Jon resealed all the roof vents because he said they looked old and were slightly cracked. We should be in good shape here for a couple of years.
10. Stove Vent - When we arrived at JC, we noticed a few drops of water on the interior wall above the stove. Jon replaced the stove vent fan exterior vent cover as a matter of fact. He said the new one comes with the appropriate gasket to make a good seal.
TankerIP is offline   Reply With Quote
Old 01-01-2010, 06:30 PM   #2
moderator
Airslide's Avatar
2014 23' FB International
Wilton , California
Images: 50
Send a message via Yahoo to Airslide
Thanks for the update Tank,
My Dad used to have a saying about ol square trailers. He said if they have the aluminum siding they all leaked. He used to wonder why they would use siding that wasnt flat and set windows and metal flanges against it only to leak later. He would caulk everything.. our trailer always had 10 to 12lbs of extra caulk on it... lol
He used to say, you want a trailer that doesnt leak you have to spend the money on an airstream! Then laugh like that wasnt possible.
Hmmm I guess he didnt know that we have our problems too huh.
"Old fashioned service on your late model Airstream"
https://www.facebook.com/VinniesNort...ir?ref=tn_tnmn
Airslide is offline   Reply With Quote
Old 09-01-2010, 09:56 PM   #3
wbrownrr's Avatar
2002 22' International CCD
San Luis Obispo , California
Thanks for your list, Tanker. I'm checking each of these spots for leaks and maintaining/repairing as necessary. I plan to keep my Airstream for a long time. This means attention to regular maintenance. Thanks again.
Wayne
2002 22' CCD
2008 Dodge Ram 1500 5.7L Hemi
wbrownrr is offline   Reply With Quote
Old 04-28-2012, 06:41 PM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Thanks Tank,
We have dealt with all but 2 & 3, will be checking those tomorrow.
Stay dry...
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 04-29-2012, 05:07 AM   #5
rd tighe's Avatar
2007 25' International CCD FB
We are , Relaxed
Images: 12
Thanks for the list.
Richard (Dean) Tighe
W.B.C.C.I. 5617
2007 25' fb International Solar
2007 Dodge
Looking for Galt's Gulch
rd tighe is offline   Reply With Quote
1950s Center of Jackson Center PeeWee Airstream History 4 08-03-2009 08:42 PM
Greetings from Jackson Center ljmiii Off Topic Forum 16 02-22-2007 11:23 AM
Jackson Center ArtStream Off Topic Forum 44 07-24-2006 08:10 AM
Small fire at Service Center at Jackson Center hohne Our Community 32 06-07-2004 10:00 PM
